Help...I think I just bought the wrong prop? >
Old 04-15-2005, 10:14 PM
Dave1972's Avatar
Default Help...I think I just bought the wrong prop?
Hey Guys (and gals),
I just bought a Bravo One prop from a guy as I've been wanting to switch from a hydromotive to the bravo one. Anyway...I got the prop and I believe it has the flo-torque hub...unfortunately I think it has the plastic insert/hub and I believe those are only rated to around 400HP. What do I need to do to this prop if I want to run it with 500HP on a standard Bravo One drive?
This may seem elementary, but I've always had the Hydromotive on the boat since the day I bought it...just wanting to try a few different things
Do I take the prop to a local "prop shop" and have them put a metal hub inside? If so, how much should I pay for something like that? I think I also need the sleeve that fits over the splines of the propshaft and into the hub of the prop...as well as a new thrust washer?
HELP!!!!
Dave1972 is offline
Old 04-15-2005, 10:22 PM
baronmarine's Avatar
Default Re: Help...I think I just bought the wrong prop?
i think you can get a metal insert from merc. i have a 26 pitch bravo with the plastic insert on my 28' with a single hp 500. knock on fiberglass no problems.
todd
baronmarine is offline
Old 04-16-2005, 01:17 AM
hillbilly24's Avatar
you just need to get a solid hub insert from merc and slide it in no big deal at all.
hillbilly24 is offline
Old 04-16-2005, 06:40 AM
Dave1972's Avatar
Who do I get the solid insert from and how much should I expect to pay? Do I take the prop to a local prop shop and have them press the new insert in? Thanks guys!!!!
Dave1972 is offline
Old 04-16-2005, 06:47 AM
Scott B's Avatar
If it is a flo torq hub, the old one will slide out and the new one slides in.. NBD..
A new one will run ya 60 bucks....
Scott B is offline
Old 04-16-2005, 11:41 AM
timewarp's Avatar
You can get the hub kit at any Mercury dealer, what you are looking for is a Flo-Torq II Solid Hub Kit
If you have a standard propshaft it is part
#835258Q 2
the list price for this kit is $71.40 this includes
12-835467 1 Forward thrust washer
850821Q12 Steel Drive sleeve
826074Q1 Aft Adapter
14-816629 Tab washer
11-827614 Prop nut
It will also come with instructions that will show you how it goes in the prop, it's an easy swap with the plastic hub.
If you don't have the standard propshaft but you have the Heavy duty 1 1/4" shaft the part number for the kit is 840389K06 it lists for $138.05
Good luck,
Caleb
timewarp is offline
Old 04-16-2005, 09:40 PM
Dave1972's Avatar
Timewarp....you ROCK! That's exactly what I was looking for. Thank you very much!!!!
Dave1972 is offline
Scarab3DMC
05-20-2006 10:07 AM
cloudmaster_321
31
04-15-2005 12:44 PM
Hydrocruiser
08-13-2004 06:34 AM
Aka8953121
06-24-2003 07:56 AM
dougB
Baja
4
05-04-2003 08:35 PM
Quick Reply: Help...I think I just bought the wrong prop?
