Help, Hole In Trs Drive!!! >
Old 05-05-2005 | 03:13 PM
Audiofn's Avatar
Charter Member #232
Default Re: Help, Hole In Trs Drive!!!
How fast is your boat? I had the nose cones on my boat and it actually went faster when I took them off. If you are not going well into the 70's you do not need them. I hate the damn things as the bondo constantly chips off and looks like crap plus as you can see the fill hole becomes a issue.
Jon
Put your best foot forward!
Audiofn is offline
Old 05-05-2005 | 08:12 PM
Pantera1's Avatar
Ahh some fill over the drain hole ..But to change the oil you have to pull the lower off and flip it on its side .. I use the cardboard sleeve that comes with new spark plugs to prtect the threads as a form to build around the drain plug hole.. Just about any type of filler/ epoxy you use will eventualy start coming apart ..metal prep is key. I use evercoat 27 ..fast , light, waterproof and easy to work with.. Screw merc paint , black Krylon works fine..
Pantera1 is offline
siearly
Drives and Lower Units
14
09-23-2023 06:19 PM
MnFastBoat
3
05-27-2008 07:48 AM
THRILLSEEKER
2
05-14-2008 04:40 PM
thayes11
0
10-02-2005 12:36 PM
Hot Boat
3
07-03-2004 10:23 AM
