Trailer hitch question
My current hitch reciever has a dip of maybe 2" to lower ball closer to ground.
The new boat now sags in front, not level. Question: can I flip the reciever upside down and have the dip go up 2" or do I need a new one. Hope this makes sense, hard to explain. |
Re: Trailer hitch question
Yep, you just answered your own question.!
yes you can flip the hitch up or down, have to do it on my rig as well.
Yes, they can be used to raise or lower your trailer tongue.
Happy towing, Caleb |
Most ball mounts are designed to be used in the "up" or "down" position. There are some, however, that are NOT designed to be used in both directions. Typically, if they are only designed to be used in one direction, there will be some sort of sticker or stamping letting you know. If you are still not sure...contact the manufacturer.
ok I'll look. I will post pic later what I am referring to but sounds like you all know. tnk u
Most 2" drop ball mounts will give you a 1" raise when flipped over. All that I have seen are made to work either way.
flipping it might raise it too much... i had the same problem and a straight one with no drop or raise got it just right...
flip it and check the height, knee high with the trailer should be fine, I have an 8 inch one on my dually flipped upwards as I lowered the truck 8 inchs.
I was told you can only flip it for the same rating if its solid steel not welded My 3" weighs about 20 pounds.
Forward sag is not necessarily due to receiver height. You need to be sure your tongue weight is right with your boat on the trailer. Tongue weight should be 5-10% of gross loaded weight. If more than that, then you could be in a dangerous situation to where loss of control down the highway; or persistent tire blow outs could be a problem. If tongue is good, then monkeying with the reciever is the last step...
| All times are GMT -5. The time now is 03:08 AM. |
