Tech Question about fuel tank vents. >
Old 05-08-2005, 11:33 AM
fruitta55's Avatar
Question Tech Question about fuel tank vents.
I have a tech. question for all of you guys. Should there be a check valve on the fuel tank breather lines? Luckly I have not filled up while on the water yet, but when I fill the tanks gas shoots out the tank vent before the auto shut-off on the nozzle clicks. If there is a part like this could someone let me know where to get one?
Thanks,
Adam
fruitta55 is offline
Old 05-08-2005, 12:28 PM
dana marine products's Avatar
Default Re: Tech Question about fuel tank vents.
Fuel tank vents vent air in and out from the tanks. There's no such thing as a one way check valve in a fuel vent. It wouldn't work. Try to figure out the capacity of your tanks and try not to overfill them.
dana marine products is offline
Old 05-08-2005, 01:51 PM
Poorsche's Avatar
Definitley get a handle on that overflow. Some marinas are real PITA if that happens and they will levy a fine of thier own. If the DEP (in FLorida) see's one overflow like that, thier officers can slap a BIG fine on you for it on the spot.
The vent has to work both ways--especially as fuel expands so vapors can be vented rather than build up in the tank.
Poorsche is offline
Old 05-08-2005, 02:43 PM
Received 1,783 Likes on 884 Posts
My fuel vent does the same thing sometimes. Try to fill it real slow when starts getting close to full.
Youi could also try one of these.
http://www.overtons.com/modperl/over...item_num=26005
Old 05-08-2005, 02:45 PM
Dave M's Avatar
I bought this "No Spill" gadget from Boater's World. It's a container with a fitting that fits over the fuel tank vent and sticks to the side of the boat with suction cups. If gas pukes out the vent it is collected by the container. When you are doen just remove it from the side of the boat and pour any gas in the container into the fuel fill.
http://www.boatersworld.com/webapp/w...oductId=713132
Dave M is offline
Old 05-08-2005, 02:46 PM
Dave M's Avatar
Griff beat me to it.
Dave M is offline
Old 05-08-2005, 03:47 PM
timewarp's Avatar
Attwood does make a "Fuel Vent Line Surge Protector" it is a check ball that allows air past both ways until gas gets there and then it seals it off. They do work, I've added them to my last 2 boats and don't get any fuel out the vents anymore.
Here's a link to West Marine, they are more expensive there but I can't remember where I got them, you could probably do a search and find them cheaper.
http://www.westmarine.com/webapp/wcs...7008&y=15&x=17
Caleb
timewarp is offline
Old 05-08-2005, 03:55 PM
McGary911's Avatar
Sometimes it's a good idea to leave a little space at the top of the tank. Often the dock's tanks are underground, and the gas is pretty cool. On a hot day, the gas can expand once it warms up, and puke out the vent. Guess this can also be considered a way to save $$$ at the gas dock??? Yeah, i know....nice try.....
McGary911 is offline
Old 05-08-2005, 04:45 PM
CMG
CMG's Avatar
I agree, they work well - http://www.boatersworld.com/webapp/...roductId=713132
just don't forget to take the cap off when filling - it can almost be air tight and air doesn't get out / gas doesn't get in. have a container to pour the over flow into also or a funnel to pour into tank, it doesn't hold the spilled fuel for long, big hole in back.
Chris G.
CMG is offline
littledcsrodshop
11-04-2007 02:03 PM
Tibbstoy2
Active Thunder
11
11-22-2006 12:04 PM
Shah Mat
07-21-2006 01:23 PM
fruitta55
Banana Boat
10
05-11-2005 08:27 PM
tmthunder
3
04-05-2002 08:44 AM
Quick Reply: Tech Question about fuel tank vents.
