-   -   427ci Small Block 934HP.. Sutphen30 heres your Big Stick (https://www.offshoreonly.com/forums/general-boating-discussion/103558-427ci-small-block-934hp-sutphen30-heres-your-big-stick.html)
Strip Poker 388 05-18-2005 11:49 PM
1 Attachment(s)
Sutphen30 I got your big stick :evilb:I bet you install your cams from the rear there so big :eek: :D
You will need ores to get this one on plane .I bet you would run this cam in your Viagra needing porcelain Tub :eek: The cam is 278/304 at .050 Lift is 847/850 cut on a 115 and has a 1.6/1.7 rocker.Or is this cam to small for ya ? :drink: It should put ya in that RPM band you like running your motors in :rolleyes:
JC Perf [Jeff] sent me this dyno sheet on yesterdays pull . It only made 934 at8250rpm On Richie Zul's dyno. sutphen30 what pitch do ya think ya need with these motors?
Here is the dyno sheet on the motor JC built :eek: :eek:He said it made more power today . Maybe he will chime in.
Titan 05-19-2005 02:07 AM
Re: 427ci Small Block 934HP.. Sutphen30 heres your Big Stick
Hey Strip!!
The big boy was on here before but I am sure he is lickin his pillowby now. I am trying to stay awake so when I get on a plane for Cali at 6am I can go right to sleep...
JCPERF 05-19-2005 10:06 AM
Originally Posted by sutphen30
now your talking,,we changed the cam alittle,,took out .21199 off the ls,,,picked up huuuugeeee power,,tried reverse duration and that was a turd :rolleyes: ,,,i'll be running some titanium 5 blades 26 pitch,,,might buzz them to a lowly 9900 rpm. :eek: :eek: :D :evilb:
was making great power till we sucked the roll of duct tape from across the room.damn jc,,ritchie doped slapped him at that moment. :D :evilb: made jc walk around in his socks to mop up the oil,too.
This would be perfect for your Sutphen.You could cruise at 8000 RPM.Just put a 10 inch pitch 2 bladed prop on your boat.You cant drink your usual 30 pack of bud with this motor though :drink: :drink:
JCPERF 05-19-2005 08:29 PM
that would be others,,i'll spin 30's to 9300RPM. :D and still be able to dock. :evilb: i have the knowledge,experience and integrity to build it. :evilb: :evilb: gotta love that hatchet idle. :D
9300? :eek:
Strip Poker 388 05-19-2005 10:22 PM
The 30 pitch 10 inch dia. :drink:
Bill You still using that Sperm whale 10 weight oil in your motors :eek: :D
