Re: How much fasted should 75hp make it go?
I forgot about that calc. It is pretty close. Their recommondations for a constant aren't very good(at least it wasn't for me), but if you figure out your own with the present motor out like Rick did it works.
The calculator claims a 5 mph gain for 75hp.
Now, take a 3000lb boat with 260hp and add 75hp. Lookie there 10 mph increase! Weight and hull efficiency play a big role. That's why the "1mph for Xhp" rule doesn't work. The calc takes these into consideration. |
but you have to determine "your " constant. If you know the top end, mph, weight, and hp, the calculator will give you the constant.
The site also has a gear ratio calculator. I tried it with the standard 1.5 bravo XR. Given the 88mph claim. I then tried the 1.35 ratio . And came up with 91mph. |
what would it be if ya had twins at 75hp each?? |
Originally Posted by JCPERF
Well a 525 makes 560 and a 600 makes 600 so you will pickup about 2 MPH
FX10, I'm getting part of the story but I wanted see what the colaberative OSO thinktank had to offer. I think anything over 85 will make for a winner. Otherwise, what's the point? |
Ron,
I totally agree. Even at this point 85 sounds good. I was readind an article in a Feb. issue of Powerboating mag. The article was on a Formula 380 Fastec hull, which formerly had 575's (not 525's) in it. It was rigged with the new 600 Merc's, and claimed a gain of between 4-6 mph. And that was with only 50 more hp. Does that sound right to you. I was going to bring the article home and scan it, then put it online here. Maybe Monday I'll do it. Rick |
"generally" bout 2-3 mph for every 50hp. seems about right.
| All times are GMT -5. The time now is 08:54 AM. |
