ac in a cig
So if i want ac in my cig how do i go about it, I assume that i will need a generator mounted in the engine compartment but does the ac unit go in there to or is it in the cabin?
Is there a factory setup for the generator? Since i was use to having a bimini top on the old boat for shade and have not seen one for the cig i figured ac would would be the next best thing to get out of the heat while parked. |
Re: ac in a cig
Call Cig. and should have all the specs when they install a/c and gen set up from the factory.for shade buy a umbrella call sunshade.portable and easy set up.
Re: ac in a cig
my ac is in the cabin but there are some ac units that mount in the engine compartment & the evap core & vent gets mounted in the cabin. it's alot easier to mount the all in one
type in a boat thats already completed. |
Re: ac in a cig
Re: ac in a cig
what he said
Re: ac in a cig
Look at the unit they put into Concepts. No gen needed it runs off of cool water in a cooler. Saw one in Key west and it worked great.
Re: ac in a cig
I have friends that use the carry on portable units that sit on the deck when parked at the marina docks...they mount over the hatches....they seem to work well.....Fred
Re: ac in a cig
Check Mermaid Marine Air--they have excellent h/w and it has smallest footprint of any of them. The cpmay also has a cool product called Condensator--it uses the cooling water to pull the condensate overboard rahter than dumping it in the bilge.
They are in Ft Meyers |
Re: ac in a cig
There is one of the carry-on type units I mentioned above for sale in the swap shop section for $300.00....check it out....Fred
| All times are GMT -5. The time now is 11:35 PM. |
