-   -   GPS Recommendations? (https://www.offshoreonly.com/forums/general-boating-discussion/103671-gps-recommendations.html)
Jnewton 05-20-2005 11:34 AM
I'm putting a few toys on my 42 Lightning and I want to set her up with a nice GPS.
The removable panel Fountain gives is so skinny (vertically) that I don't think I can find a screen small enough to fit. I hesitate to put in a bracket mount with the concern that it will try to bounce all over the place in rough water.... although the built in antenna would be a big plus.
Do you guys use bracket mounts?
Thanks for the input.
NJSONIC 05-20-2005 11:36 AM
Re: GPS Recommendations?
How big is the panel??
Jnewton 05-20-2005 11:41 AM
Panel is 6 inches high, but maybe 5 or so clear space behind.
dyno 05-20-2005 11:42 AM
Navman 5500I best deal around I bought mine from Brokenlegdave with the rebate its about $300 for a color plotter and yes i use the bracket.
Stormrider 05-20-2005 12:22 PM
garmin 276c, don't know the space available.
But the mount is on good.
waterheater 05-20-2005 12:23 PM
Have a Garmin 182C mounted on a bracket, no problems
Milord 05-20-2005 12:57 PM
How is it? I bought the same one with a new chip and the fuel monitor thingy but haven't got the GPS yet.
East Coast B 05-20-2005 01:44 PM
I was limited on space and went with the lowrance m68c which is a combo gps/depth sounder and very compact. Can mount on top of dash or in dash flush mount. Pretty neat setup if you don't have a lot of room..... I have it on top of the dash with velcro right now and am planning on flush mounting it when I redo the dash next winter. You can get the cutout template from their website and they have a gasket you can buy if you flush mount it.
Good luck!!!
HUSTLEthis 05-20-2005 07:46 PM
We have the 182c and it works great...should have bought it years ago...
MarkSmith 05-20-2005 10:49 PM
How does this compare to the Garman 182c?
