Scary fast (for me anyway)
OK i am ready to get chewed out but i just wanted to express my thanks to the board. Last night i had my boat up to 94 on gps and i was at 5200 rpm and plenty of stick left. I am not going to go this fast again until I get external steering on it. And.... next time, helmets.... It honestly felt great and it was effortless. it felt like driving a car at 75 mph on the interstate. The motor has about 6 hours on it and i have broke so many little 300 dollar items i am scared to push it to its 6,000 rpm limit. I am none the less a very happy camper :D :evilb: :D :evilb:
I am thinking that the prop that i have must be tweaked or my tach is off. At this speed and rpm i am getting 7 % slip which is really hard to achieve?!?!?! I am thinking that the prop is probably closer to a 28 pitch even though it says 27 on it. This puts slip at 9% which seems more realistic. It has a ding or two in it and seems shaved a bit. But it is in overall decent shape. How much can you tweak these props/stretch pitch? It is a mirage 3 blade on a twin step Eagle. Are these realistic numbers? What is a reasonable amount of slip to expect? i had about 30 gal of fuel on board and two people...... |
Re: Scary fast (for me anyway)
SWEET!!! Definatly get the steering at those speeds!! :eek: :D Helmets, neck braces and Lifelines also. You should get an on board video at that speed :cool:
i wouldnt run over 80 with out external steering...NOWAY.
Extermal steering is a must, I've heard its recommended on anything that does over 70. I could asume it could get pretty messy if something were to break at those speeds. Thats movin out though keep it safe!!
Your numbers seems off. Are you running a 1.36 drive? Even if you are I come up with 4% with the 27 pitch and 7% with the 28 pitch. Those kind of slip numbers are about impossible with a single engine 28' boat. If you are running a 1.50 drive you are at a neg. slip.(that's not at all possible) What kind of Hp are you running? Are you sure your tach and GPS are funtioning properly?
I run closer to 14% with a single engine 30' er and a stepped hull. 4% and 7% seems impossible. |
Originally Posted by BADKACHINA
Your numbers seems off. Are you running a 1.36 drive? Even if you are I come up with 4% with the 27 pitch and 7% with the 28 pitch. Those kind of slip numbers are about impossible with a single engine 28' boat. If you are running a 1.50 drive you are at a neg. slip.(that's not at all possible) What kind of Hp are you running? Are you sure your tach and GPS are functioning properly?
I run closer to 14% with a single engine 30' er and a stepped hull. 4% and 7% seems impossible. that is what i am saying about the slip numbers.... i am running a 236 eagle. with DD 2003 numbers of 540 CID 713 hp?????? This is a estimation, The boat from Eliminator weighs 3400 with a merc 330 hp( mine has aluminum heads and intake and exhaust)Yes the drive is 1.36. I was running downstream but at a area of the river where it is really slow and wide(maybe 2 mph more like 1 mph). We had a beer or two and i did not want to go that fast again without the proper safety equipment/steering. |
Who cares about slip numbers? That puppy is hauling ass! :drink:
I'm with Cuda....Haulin' AZZ.....who cares about slip at that speed!!! :eek: :D If you can go fast enough to suck the beer out of your can....Thats fast enough for me!!
I've flown out of a boat at 80 w/o safety equipment on and when I woke up 4 days later....it still HURTS!!! :p Get the 'quipment for the next run!! :D |
Very nice performance from a single engine vee! Definately get steering and at least a lifeline poker run jacket. Choose your water wisely! As for your slip #'s 10% on a vee is almost unheard of. Normally 15% is in the ballpark. My 23' cat runs at about 12%. Check your tach and have fun!!!
Craig |
| All times are GMT -5. The time now is 09:56 AM. |
