A dumb throttle/shifter question >
Old 05-30-2005 | 11:10 AM
From: A tree somewhere in the woods in Clarcona Fl.
Default A dumb throttle/shifter question
I'm trying to find out if anyone here knows whether a set of controls(like gafrig or Zero effort) controls will work with the existing cables on my new 27pc Formula? I've never had a set of standard twin engine controls in my life and so far I'm not liking them so much especially during low speed maneuvering.
Next question is do any of you offshore brothers have a set of used ones that they would like to get rid of for a reasonable price so that I can experiment with this setup?
Nick
Slick02 is offline
Old 05-31-2005 | 07:30 AM
Default Re: A dumb throttle/shifter question
Nobody got any idea???
Slick02 is offline
Old 05-31-2005 | 07:36 AM
cuda's Avatar
Do you mean the shift and the throttle in the same stick?
cuda is offline
Old 05-31-2005 | 07:51 AM
gotime34's Avatar
I have a 32 foot wellcraft excalibur that I'm working on that has that set-up, and I want to change to the seperate drive and throttle, but its a twin engine boat, is yours a twin? Also I had the same question as you, can you switch between the 2 or do you need a whole new system?? If I switch I will gladly give you mine, but that may not be for a few months. Gotta finish the one in the water before I play with the one on land.
gotime34 is offline
Old 05-31-2005 | 08:01 AM
Ted G's Avatar
The standard Mercruiser cables will not work with the zero effort style controls. To do the job you need to by 4 3300 style cables and 2 Mercruiser adapter sets. The controls will take the cables with no adapter but the engines need them. I always use Teleflex TFXtreme cables and you will be amazed at the difference they make. You can look on the cables near the ends and they should have a number that will give you the length-either in inches or feet.
Oh and a plug- www.boatfix.com has real good prices on the cables and adapters, Trick Marine has the controls
www.cbpba.com
Ted G is offline
Old 05-31-2005 | 08:02 AM
cuda's Avatar
If that is the problem, the answer is yes, you can use the same cables. I just changed them in my Formula. I had to buy different pivots for them. Trick can get the pivots.
cuda is offline
Old 05-31-2005 | 09:30 PM
Joe,
I got used to the seperate throttle/shift levers for each engine like my fastech had and now with the twins in the pc the shifter/throttle setup is a single stick per motor, and I'm having a real problem getting used to controling the low speed manuvering with my present setup
Slick02 is offline
Old 06-01-2005 | 04:22 AM
cuda's Avatar
That's the way my 302 throttles were. I just switched them out for Gaffrigs, cables are the same, I just had to get longer pivots.
Attached Thumbnails A dumb throttle/shifter question-throttle-area.jpg   A dumb throttle/shifter question-enhanced.jpg
cuda is offline
Old 06-01-2005 | 07:59 AM
Ted G's Avatar
Cuda's are the standard 3300 cables. I think that the old shifter was a Teleflex/Morse or an older style Merc. If you have that type of cable you can switch no problem.
www.cbpba.com
Ted G is offline
Old 06-01-2005 | 09:57 AM
Thanks for the pictures/information....guess I'll take mine apart and see whats what.
Slick02 is offline
mpally
Baja
14
11-25-2013 11:43 AM
axapowell
Wanted
7
04-01-2008 08:02 PM
bluewater7
02-13-2007 01:36 AM
S4Hadi
3
03-20-2006 07:48 PM
SkiDoc
9
10-07-2005 08:13 PM
