-   -   cross post -- need help fast please (https://www.offshoreonly.com/forums/general-boating-discussion/104666-cross-post-need-help-fast-please.html)
CHAOS REIGNS 06-02-2005 11:38 PM
hey guys
need help pretty quickly -- got a motor guy putting my boat back together -- he is not a marine person
motor is in ready to fire -- ive got a merc II tranny and trs drive -- on the tranny there are two water lines (cooler)-- i'm assuming one goes to the rear port of the exhaust as an exit -- but where does the inlet line go to?
can i just tee off of the outlet of the raw water pump -- prior to it going into the block?
this is a new motor and i don't have any of the old stuff for reference.
thanks for a quick reply -- i need to call him so i can have my boat back!!!
mark
AIR TIME 06-03-2005 05:24 AM
Re: cross post -- need help fast please
do you have a factory oil,powersteering cooler or is it missing.my buddy;s boat has the trs set I will swing by his boat to day and check it out ART
Poorsche 06-03-2005 05:57 AM
1 Attachment(s)
Here is a diagram of a closed colling system--shows cooler location for you.
Cooler(s) are between water pickup and raw water pump. Trans is connected to one of coolers (power steering is other one) and dumps thru the block/manifolds. I've got a pair of dual collers that are brand new -- make a great deal on them.
Mbam 06-03-2005 07:23 AM
The stock set up had a fitting in the drain plug on the brass bodied sea pump. That cooler does not need much water, it is only a 3/8 hose. So yes, T off the outlet of the sea pump, the origiial fitting was 1/8 npt (about a 1/4" ID).
el indio 06-03-2005 07:38 AM
good morning marc.chicago just aint the same wiyhout you.............cya m.m.............
CHAOS REIGNS 06-03-2005 05:16 PM
thanks for your help guy's!!
Mbam 06-03-2005 05:34 PM
hi Mark, yep it is just not the same w/o Chicago.
Coming down any time soon?
el indio 06-03-2005 05:37 PM
1 Attachment(s)
july.want to plan a trip?......m.m..........
