-   -   Performance gain predictions, 28 Daytona w/Raylar 496 HO's? (https://www.offshoreonly.com/forums/general-boating-discussion/105108-performance-gain-predictions-28-daytona-w-raylar-496-hos.html)
Harper220 06-08-2005 03:19 PM
I've been kicking around adding the 496 HO Raylar kits. I need some input based on current stock numbers and possible expected gains after adding the kits.
Here's what I got: 28 Daytona 496 HO's XZ drives, no boxes and prop shafts even with bottom of boat running 29p Hydro P5X's.
Current #'s
3000 rpm's = 52 mph
3500 rpm's = 62 mph
4000 rpm's = 72 mph
4900-5000 = 90-92 mph WOT
The kits are said to raise the 496 HO to 525+ hp and 610 ft. lbs. torque @ 3800 rpm's. I definitely want the reliability with 87 octane and no super chargers.
I figured if the kits allowed me to add 3-4 pitches, I would see at least a 10 mph gain at 3000, 3500 and 4000 rpm's with the possibility of 12-15 mph at WOT.
Any predictions would be appreciated... :D
Sean H 06-08-2005 03:27 PM
Re: Performance gain predictions, 28 Daytona w/Raylar 496 HO's?
what does a 28 w/ 525's run? i would assume you would be real close to that...
and you might not end up adding as much prop as you think, but turning more rpm....
