-   -   Check out the diference: TRS vs #V's (https://www.offshoreonly.com/forums/general-boating-discussion/105370-check-out-diference-trs-vs-vs.html)
kevinr 06-12-2005 12:30 AM
2 Attachment(s)
found this pic , was suprized . same boat new paint Also notice the prop rotation, this is the way Galen at SPEEDMASTERS told me to run them on the V's . Is this In or Out; been reading all the threads on prop directions.( lots of opinions).
bob 06-12-2005 07:44 AM
Re: Check out the diference: TRS vs #V's
TRS are spinning out. V's are spinning in. U-joint centerline to propshaft centerline on a TRS (25.12") vs a V (18.7")...V is 6.45" shorter.
kevinr 06-12-2005 03:49 PM
You are right, put alot of study in before I mounted them. They are as high as I could put them,without pluging the transom & moving eng's up. X About 2" below the surface of the bottom. Takes forever to plane and slips real bad comming out of the whole,but once it comes over ,hold on...............any comments....................anyone
Boat: 88' Cig Top Gun
Full cabin ,all fiberglass
850Ft lbs per eng. Supercharged
12,000 lbs
17x29 cleavers 1.50:1 ratio
nauti-buoy 06-12-2005 05:04 PM
I have always wondered if a Speedmaster Drive would fit the TRS transom assembly. Can you still get parts for a number V drive??? by the way that is a sweet ride!!! :evilb:
kevinr 06-13-2005 06:33 PM
No It wont, had to buy all of that, It will cover up the hole though and yes you can still buy V's and parts
fred 06-14-2005 05:34 AM
Have you got a speed on it yet?...just wondering what difference the drive change made....Fred
kevinr 06-14-2005 05:17 PM
No not yet, having to catch up work in the machine shop
fred 06-14-2005 06:19 PM
Let us know when you do, would be interesting to see what difference it makes....is everything else motor wise the same as it was only the drive change?
kevinr 06-16-2005 09:18 AM
Not exactly, old eng. 540ci single Dominator 600hp, New engines 540ci merlin heads 871 BDS's twin dominator 850hp
