-   -   White Vinyl in Cabin Devoloping Yellow spots..Help (https://www.offshoreonly.com/forums/general-boating-discussion/105939-white-vinyl-cabin-devoloping-yellow-spots-help.html)
gripit 06-20-2005 08:31 AM
I'v noticed my white vinyl in my cabin has developed some yellowish discoloring in some areas. I was wondering if this is mildew? I'm not sure?? Has anybody had this happen to them and whats the best way to remove this?
Wellby 06-20-2005 08:36 AM
Re: White Vinyl in Cabin Devoloping Yellow spots..Help
I covered my dash in white vinyl last year... I've got the same problem. I think bleed-through from the glue. Mine is not real bad, but it really makes me mad from all the time it took :mad:
gripit 06-20-2005 09:11 AM
I dont think its the glue in my case. Its not a new vinyl job and just noticed it yesterday. I think its related to the summer humidity, but not sure?
offthefront 06-20-2005 09:21 AM
I looked at a 353 fromula that had the same problem in the white marine vinyl inside the cabin ....not sure what it is or the cause but sure is a bummer ....
PhantomChaos 06-20-2005 10:20 AM
What the heck are you doing in the cabin? Wipe up after you're done! :D :D :D
Indy 06-20-2005 11:29 AM
I've noticed that before also :confused: In areas where it's never been touched also!
Tantrum 06-20-2005 11:30 AM
Cant believe it made it 5 posts with out a comment.
:drink:
BillR 06-20-2005 12:18 PM
I had the same thing in my cabin. I had a vinyl repair guy come and re-dye the vinyl. Looks new now.
I never was sure what caused the spots. One person suggested mildew on the backside bleeding thru.
Let me know IF you ever figure out what it is.
PatriYacht 06-20-2005 12:27 PM
Bleach will clear up mildew stains. A marine repair shop recommended it to me. Our ski boat always has mildew after winter storage, been using it for years with no ill effects on the vinyl.
gripit 06-20-2005 12:30 PM
Patriyacht, How do you apply your bleach. Straight or diluted?
DanB 06-20-2005 12:56 PM
Sun block and lotion combined with sweat will cause white vinyl to get a yellowish stain. My wifes bolster turns and mine doesnt because I dont use either.Usually if you wipe it down with bleach and then water right after it will go away. Keep the bleach off the stiching!!
X-Rated30 06-20-2005 01:14 PM
If it is yellow, I would bet it is mold, and not mildew. I have a friend that had this happen to her BMW that she kept in a hot garage in Dallas.
BillR 06-20-2005 02:23 PM
Whatever I had; NOTHING would touch it. I tried everything. Thus I think it was under the vinyl.
Now it looks stunning!
gripit 06-20-2005 02:48 PM
I don't know what the hell it is, but I'm going to try x-14, whesley bleech, and if no luck then good old fashion clorox. In that order. Hopefully, one of them will work!! I will let you guys know.
Indy 06-20-2005 03:30 PM
You might be on to something here, sunblock + sweat = yellowish stains on my t-shirts. I just shoot some Shout or something on it before I throw it in the laundry.
PatriYacht 06-20-2005 04:18 PM
Use the bleach a cup or two in a gallon of water with some laundry detergent. It'll make the skin on your hands peel, so wear gloves. Let it sit for a while then scrub with a brush then rinse. On bad stains I've poured it on full strength. Don't drop it on anything with color like the carpet. My ski boat is 12 years old and the vinyl still looks great.
Poorsche 06-20-2005 04:24 PM
Might be worth trying those Mr Clean Erasers before tryiong bleach. I used some Wesleys on white vinyl and it seemed to remove the top layer of the finish. It's never looked right since I tried Wesleys on the vinyl and it's never changed anything else. THe erarsers seemed to work very well with out chaning the vinyl.
Strip Poker 388 06-20-2005 04:37 PM
I second the Eracers. It worked pretty good on my interior
gripit 06-20-2005 08:12 PM
Nothing works. X-14, Whestles, bleach, Nothing will remove these yellow stains. I going to look behind the vinyl and see if its coming from behind. I'll let you know.
Back4More 06-20-2005 08:21 PM
Try RollOff and get some light on it.
gripit 06-20-2005 09:32 PM
I pulled some vinly off and found the problem. I can see yellow glue behind the vinyl attached to the foam. The glue is staining it from behind. I think I'm screwed.
Fast Forward 06-20-2005 09:43 PM
Last year I had my rear sun pad recovered by the factory. I than had a new storage cover made which was a blue colored canvas. After the canvas got wet it left blue stains in my new sun pad. I tried everything from bleach to soft scrub with no luck. I was so upset I decided to take it back and have it redone again. Just before making the call I went out in the garage and grabbed every cleaner/solvent I could think of. Figuring if I took the color out at this point no great loss. Well I ended up with fingernail polish remover. It took the stains right out with no damage to the vinyl. I than made sure I cleaned it off very well and applied a vinyl conditioner after words. Put a little on a rag and wipe lightly. If the vinyl is anything but white I wouldn't try it. Just be careful that you don't use to much or you could remove the grain from the vinyl.
el indio 06-21-2005 11:54 AM
acetone.........
Gofastboater45 06-21-2005 12:29 PM
I've used soft scub with bleach, but cant leave it on too long or it will yellow the vinyl, and keep it off the seam threading ! It cleaned stains good & finger/toenail polish scuffs & marks from the ladies, but had to be careful with it. BTW, it works great on white ribrails ! :D
BillR 06-21-2005 02:22 PM
Re dye it.
It's cheap and looks 100%
Fast Forward 06-21-2005 04:45 PM
Yep! Acetone, Sounds crazy but it worked for me. I tried it on some extra vinyl I had to see what it would do to the grain. I did find if you left it on to long it would start to desolve the grain. Just put a small amount on a white rag and rub lightly than make sure you wipe it off with some soapy water and than with some conditioner.
