-   -   353 no rpm's whats the problem (https://www.offshoreonly.com/forums/general-boating-discussion/106490-353-no-rpms-whats-problem.html)
Killa K!!! 06-27-2005 08:32 PM
i have a formula fas tech 353 with 500efi and zx drives spining 4 blades 30 labs . the boat has 160 hours on it and have never seen 80mph with yet best i ever got was 4850rpm at 77.7 mph gps any tell me why i ant turning at least 5 grand and what elese to to do get rpm and mph i have heard facing drives in ward gets you 1 to 2 mph get back to me .
remark66 06-28-2005 02:08 PM
Re: 353 no rpm's whats the problem
Try a smaller prop. maybe a 28 four blade.
dreamer 06-28-2005 02:16 PM
1 zx drives?
2 props need to spin in( well not "need" but will be faster)
3 check the props... 30 labbed doesnt mean 30 labbed, have the pitch checked also who labbed them? sounds like a botched job non labbed should be 80mph
4 where are you? altitude?fresh or salt?
turbosonic1 06-28-2005 03:10 PM
The 353 has too much negative trim so straight edge the drives with the bottom and mark that on your indicator as neutral. Then trim it up 2-3 clicks from there. You may want to try some hydromotive 27 pitch 5 blades on that boat. You are not getting enough rpm!
Killa K!!! 06-29-2005 08:53 PM
my bad xz drives and i live in toms river Nj salt water .
