496magho/bravo water problem
out in the inlet jumping some waves ....overheat buzzer came on no water coming out.......opened both blue plugs at pump with drive up water comes in, drive down it doesnt, closed plugs fired it up ----drive up water pumps fine drive down water is not coming out
is it the impellor? or is there a hose that may have moved that is getting pinched? thanks |
Re: 496magho/bravo water problem
Last month the water inlet hose to the oil cooler split when I was running WFO. Hose just plain burst. Had a 2 inch slit in it. The hose could hold 5 psi when idling back to the docks but no more or would spill in bilge. Like a $20 hose or somethin like that. When kneeling on back seat looking aft, the hose was on the aft left side of the motor. Was there any water in the bilge?
Did you come across the problem, just wondering in case this problem may arise for someone else... :rolleyes: :D
the problem was that the hose was pinched up in the gimble, obviously from a huge water hit in there, the impellor was fine i replaced it anyway, still acting up intermittently......still searching
| All times are GMT -5. The time now is 10:13 PM. |
