Bouncing Tach
At higher rpm my tach starts bouncing. It's on the money and steady until about 4500 rpm. When I am trimmed out and running 5000 rpm it's all over the place. I replaced the tach and the new one does the same thing? :confused:
Looked for the obvious loose wire and found nothing. Could this be a sign of a bad ground? |
Re: Bouncing Tach
Are you hitting the Rev limiter? My old Checkmate would bounce at wot when it was hitting the limiter?
Re: Bouncing Tach
Not hitting the limiter, checked it with a tach that clips around a spark plug wire and I was right at 4950-5000 rpm when trimmed out. It starts at about 4500 and gets worse as the rpms increase. Under 4500 it's steady and accurate. :confused:
Re: Bouncing Tach
CHECK THE DIST CAP A BAD CAP WILL CAUSE TACH TO JUMP
JOE AMERICAN PERFORMANCE MARINE 410-573-0057 [email protected] |
Re: Bouncing Tach
Okay, now I'm gonna sound stupid but I don't think my motor even has a distributor?
It's a 2003 Volvo Penta 5.7 GXi |
Re: Bouncing Tach
Mine does the same. Merc 575SCi
replaced cap & rotor same problem. Still looking for a cure too |
Re: Bouncing Tach
Mine was doing that last weekend. Spent about an hour touching every connection and trying to move every wire. I didnt find the loose groung I was looking for but when I ran the boat this weekend it was dead on. one of the plugs on the wiring harness must have been loose.
Re: Bouncing Tach
same problem on my playboy
Re: Bouncing Tach
"prongs of the cannonball plug"
you mean the doohicky in the whatcha-ma-thing? laymans terms please... or ill just tell my boat wrench-a-thingy guy :cool: |
Re: Bouncing Tach
I had the problem and the electricals shut my motor down. Ended up re-wiring the port side ignition and something near the distributor
