Dyno  print out on a set of engines >
Old 07-20-2005, 07:54 AM
45 Lip Ship / 900 Zul's
ONESICKGLADIATOR's Avatar
Default Dyno print out on a set of engines
Dyno sheet on a pair of 800+ Richie Zul Engines
Rick OSG
Attached Thumbnails Dyno  print out on a set of engines-800-mills.jpg   Dyno  print out on a set of engines-osg-port-engine-dyno-sheet-web.jpg   Dyno  print out on a set of engines-osg-starb-engine-dyno-sheet-web.jpg
ONESICKGLADIATOR is offline
Old 07-20-2005, 08:06 AM
Default Re: Dyno print out on a set of engines
Nice numbers....killer torque.....I'd take them.....Fred
fred is offline
Old 07-20-2005, 08:18 AM
throttleup's Avatar
6200 looks like the place to be!
Julie
throttleup is offline
Old 07-20-2005, 09:31 AM
Hydraulic or solid cam? Nice numbers!!!
WETTE VETTE is offline
Old 07-20-2005, 09:47 AM
stecz20's Avatar
show off....
stecz20 is offline
Old 07-20-2005, 10:12 AM
Semper Fi's Avatar
Nice
Semper Fi is offline
Old 07-20-2005, 12:34 PM
FASTERDAMITT's Avatar
Looks like your numbers are a little better than I ran with a single carb set up. Let's see more of your specs. Heads, cam, intake, carbs, comp... I idle at 900 or so, how about yours? I would have liked to see how it does at 3500. My info is on the dyno sheet. Should run hard.
Attached Thumbnails Dyno  print out on a set of engines-598-large-.jpg   Dyno  print out on a set of engines-dyno-001-large-.jpg
FASTERDAMITT is offline
Old 07-20-2005, 12:35 PM
masher44's Avatar
Originally Posted by stecz20
show off....
Price just went up 20K on that boat with THOSE numbers...
masher44 is offline
Old 07-20-2005, 01:13 PM
Rob
Strip Poker 388's Avatar
Steady state pull
Strip Poker 388 is offline
Old 07-20-2005, 05:42 PM
You have to call Richie Zul to get more specs on these. I do know these numbers are on 93 pump gas.
Rick OSG
Quick Reply: Dyno print out on a set of engines
