blackhawk drives
blackhawk drives
does anyone know about blackhawk drives? i have one with the prop shaft wiggles slightley and the two props rub so slightley together. any suggestions?
Re: blackhawk drives
Originally Posted by Airpacker
Get it apart and checked. Sounds like you have a bearing between the shafts gone. Mine are perfectly tight, no lateral play at all.
Official OSO boat whore
Sounds like a bad bearing to me. Get ready to spend some dough too. You will proably end up rebuilding the entire drive before you are done. Post back on the board if you run into any problems getting parts.
[QUOTE=noboat]I don't know what you mean by "wiggles" but my blackhawk had slight play between the inner and outer propshaft. If I remember correctly there is supposed to be a few thousandths of an inch there.
Did you check your thrust washers?[/QUOTE
yes the thrust washers are ok
