Props Needed Desperately
Need a set of cleavers (left and right) 15 x 27 or 28 to fit a No. 2 SSM with 19 spline and what I'm told is the small diameter shaft. I believe the larger diameter shafts were available with the No. 4's and standard with the No. 5's
Can be new or used. We are racing at Cowes in three and a half weeks and there are absolutely none at all in the UK. Would be very much appreciated if someone could steer me in the right direction. |
Re: Props Needed Desperately
If you cannot find a small shaft propeller, I make the adapters for the large shaft propellers to the small shaft.
Thanks Rik, if we can't source the props, we will be in touch.
What do you charge for the adapters by the way? |
What is the hub length? They come in 4" or 6" ?
I should have something. |
Hub length is 6" but I can probably use 4" also as we have a set of spacers.
Bam Marine.
Cobra Power Dollar Offshore These are the first places I would check out. All are great people to deal with. Julie |
Thanks very much Julie. I will contact all three.
| All times are GMT -5. The time now is 03:58 PM. |
