arneson drive
anyone know how much the bravo to arneson conversion kits that bolt up cost? any experience with them?
Re: arneson drive
I think they run about $16k on up per side. Call Rik, he's on the board and I'm sure if he's not budy chasing some tail he'll pick this up.
http://www.arneson-industries.com/ Arneson Ind San Rafael Ca 415.485.0788 |
Re: arneson drive
The Arneson does not require any of the parts from the Bravo. The ASD6/Bravo Conversion kit will give you everything that you need to use the Arneson on the boat. Our standoff box will cover the cutout of the Bravo eliminating the need to re-glass the transom. The ASD6 Bravo Conversion Kit includes the following: Char-Lynn Hydraulic Helm Unit Gil HD Rear Engine Mount HD Drive Plate HD Bellhousing New Modified Velvet Drive Transmission 900 HP rating. Drive Line Arneson Standoff Box Arneson ASD6 Drop Box Drive Unit: Complete with External Hydraulic Steering and Trim Cylinders, Trim Pump, Mounting Bolts, External Hydraulic Hoses, Trim Pump and Mounting Instructions/Drill Template. The ASD6 Drive Unit and the transmission come with a one year warranty in approved applications. Options: HD Gear Upgrade: $900.00 Transmission Upgrade: $400.00 List $15,500.00 ea. F.O.B. San Rafael, CA USA Thank you, Rik Wimp Arneson Industries |
Re: arneson drive
What info do you need?
Take a look at this thread http://www.offshoreonly.com/forums/s...d.php?t=108728 What boat/power do you have? |
Re: arneson drive
Rik how about listing some of the performane increases with various hull designs so everybody can understand that you get reliability with performance and lower cost new over most setups.
| All times are GMT -5. The time now is 04:01 AM. |
