Help with surface drive.
Old 08-05-2005 | 02:37 PM
Default Help with surface drive.
Anyone out there maybe help me with a drive I'm building??? It's kinda like an arneson, but doesn't steer with the rear housing. I do need to trim though, and the u-joint I used couldn't handle the 500 HP the motor has now, and I'm building another one that's going to put out about 850 to 900 HP. What kind of universal/CV do they use in those things. This is the first boat I've ever had with a surface drive on it. Thought I'd build one since I'm on such a low budget Thanks for anyone's thoughts.
Eric
cjsdad62 is offline
Old 08-05-2005 | 02:55 PM
Frequency's Avatar
Default Re: Help with surface drive.
You might find some info at www.pulsedrive.net. They use the same ujoint assembly that merc uses on the #6 drive - should be beefy enough.
Frequency is offline
Old 08-05-2005 | 04:27 PM
cuda's Avatar
The ujoints on my Kaama's are Spicer. I can't remember the number. When I had the tranny out, I told them to replace the ujoint, he said there was no need, they showed no signs of wear, other than a little surface rust from a leaking boot that have since replaced.
cuda is offline
Old 08-06-2005 | 04:57 PM
Thanks for the tips. So...I was reading some other threads and replies, and noticed some say that a single surface drive can get pretty crazy at high speed??? How high. I have a 1990 28' Solution, which is almost exactly like the old formula bottom. Would I be safe doing 80 or 85 in this with one drive? I guess I need to upgrade and maybe show you guys some pics.
cjsdad62 is offline
Old 01-25-2009 | 07:22 PM
how did you get on with the drive what prop is that on your drive
gerard is offline
Old 01-25-2009 | 07:36 PM
most of the u joints are heavy truck stuff 1450 series Spicer I belive
riggerjohn is offline
TexomaPowerboater
Pantera
26
10-02-2007 01:43 AM
tblrklakemo
Active Thunder
3
09-05-2006 09:41 PM
thayes11
0
10-02-2005 12:36 PM
imongo
Cigarette
5
11-05-2002 09:37 PM
imongo
11-04-2002 11:31 PM
