-   -   OT ... Percolation test ??? (https://www.offshoreonly.com/forums/general-boating-discussion/112282-ot-percolation-test.html)
LEOPAJM 09-13-2005 09:59 AM
OK guys ....builders , contractors ect... If a lot fails a "percolation test" .... what does that mean ?????
Thanks !
JM
Wobble 09-13-2005 10:12 AM
Re: OT ... Percolation test ???
I think it means you cant run typical septic lines under the ground. Here is an article on the test. http://www.extension.umn.edu/distrib...es/DD0583.html
Your option may be an aerobic system with sprinklers, which is what I have. This system depends on the area you have + it uses sprinklers.
Viper31 09-13-2005 10:16 AM
I think your only option at that point is to haul in proper mix of dirt and mound it if the lot conditions allow for it. Every county has different rules for this problem. Do you already own the lot?
LEOPAJM 09-13-2005 10:43 AM
Don't own it yet .... Thanks so far guys ! Anything else ? Waiting to hear from the agent here ???
RHC 09-13-2005 10:55 AM
Jerry,,, In your area ,, it means that the soil conditions are not accepatable for a septic tank ,,, the ground will not absorb the waste water and filter it at rate fast enough to insure that the final water product that comes out of the septic discharge tank will be safe to consume,,, Yep ,, you heard me rite,,, if the system works right and the soil filters the waste water, the discharge should be safe to consume... What the bottem line is ::: Discount the price of the Lot to cover the upcharge of putting in a Mound or Small sewar Plant ,,, The current owner will have a hard time selling it under these conditions!!
Real Estate 101 :D
RHC
LEOPAJM 09-13-2005 12:07 PM
Real Estate 101 :D
RHC
I knew I could count on you for something like this ! :D
Caincando1 09-13-2005 12:10 PM
Pressure mound...trust me I'm learining the hard way on a house I've owned for 7 years... :mad:
BajaRunner 09-13-2005 12:25 PM
I just bought a property with an aerobic septic system. Here you have to have a contract with a "certified inspector" to check it every 4 months, along with adding septic chlorine.
It looks to cost me about $400-$500/year whereas a normal septic doesnt cost anything. (for the most part)
GLH 09-13-2005 02:02 PM
"If it don't perc don't buy"
There are ways to make it work but it always become a marketing challenge when you want to sell, since your system is not run of the mill...
Might be good for you however cause a guy your size can't generate that much waste anyway...
:D
birdog 09-13-2005 02:04 PM
It means big $$ for an arobic or a nasty looking mound system :(
