Small diesel engines ???
Old 10-04-2005, 01:56 PM
GregP's Avatar
Default Small diesel engines ???
Ok world wide knowledge base, I need to find some candidate 3HP diesel engines. It will be going into a helicopter so "light" is a key factor, followed by reliability and no-fuss starting. Air cooled preferred, but will look at water cooled if I can handle the radiator weight.
-Greg
GregP is offline
Old 10-04-2005, 02:08 PM
jordy's Avatar
Default Re: Small diesel engines ???
Light and diesel don't really go together very well. Yanmar would be a good small diesel candidate. I've got a spec sheet and they make a 4hp (L48EE) air cooled engine that makes it's power at 3600rpm. Dry weight is 26.5kg with a pull start. That's right around 58 pounds plus fuel and oil.
jordy is offline
Old 10-04-2005, 02:18 PM
GregP's Avatar
Yes, most small diesels are much too heavy. I need the weight to be around 10-12 lbs for the base engine w/o starter.
Thanks - Greg
GregP is offline
Old 10-04-2005, 02:21 PM
jordy's Avatar
10-12 lbs? You're almost going to be stuck in the realm of some kind of 2 stroke weed whacker or chainsaw engine or something along those lines. Good luck though.
jordy is offline
Old 10-04-2005, 02:23 PM
CigDaze's Avatar
Why not a microturbine? It's the only way you'll get the power to weight ratio you're looking for reliably.
CigDaze is offline
Old 10-04-2005, 02:27 PM
CigDaze's Avatar
http://www.wren-turbines.com/turboprop.htm
7.1HP at only 3.52 pounds.
Helicopters:
http://www.wren-turbines.com/Helicopters.htm
CigDaze is offline
Old 10-04-2005, 02:31 PM
GregP's Avatar
Started by looking at model aircraft diesels, but they don't go big enough (only about 1.5 HP) and aren't really reliable enough.
We have some of the micro-turbines and are looking at them, but the sfc is the pits (about 2.7#/HP-hr).
In the past we have worked with companies like Sonnex and UEL to convert gas/spark engines to heavy fuel (diesel) but none of them really fit this application.
If it was easy I wouldn't have had to invoke such a large support base to find a solution
Thanks - Greg
GregP is offline
Old 10-05-2005, 08:11 AM
CigDaze's Avatar
Ya, I can understand the fuel consumption aspect. The unit in my link above consumes about 3.62 #/HP-Hr, but that's at wide-open making 7.1 horsepower. If you only need 3HP, the smaller turbine consumes about 2.1 #/HP-hr. Probably still too much. Tough project.
Your next best bet is a small Ion Generator fueling a dispersive high-energy rotary powerplant. (I might just have to go patent that).
CigDaze is offline
Fortius
01-31-2016 08:31 PM
scottw
10
10-03-2008 07:00 AM
wannabe
General Racing Discussion
8
11-15-2006 12:58 PM
big-boss
Cigarette
42
06-17-2006 07:44 PM
super termoli
11-04-2004 09:57 AM
Quick Reply: Small diesel engines ???
