I know I shouldn't ask!
I know I shouldn't ask! BUT, at cruising speed what kind of fuel consumption would one see driving a 419 w/triple HP500's. This boat would be a big step for me. Fuel consumption could possibly be an issue... :rolleyes:
Re: I know I shouldn't ask!
I would guess hat you would be in the 1-1.5 gpm range. Nort aka PhantomCaos should know. His Sunseeker has tripple 502's. Just bump up his numbers a little bit.
Jon |
Not to rain on your 419 parade, but I remember reading somewhere that the Formula 419 breaks bravos like no tomorrow, because of all the weight. I almost bid on one awhile back, and did some investigating and decided to pass..... I think that was part of the reason for Formula to stop making it.
Good luck, Dean |
Someone I know with a 45 Sonic with trip 500's told me he is burning 50 GPH at cruise. :eek:
If it helps. Just hooked a scan tool to my 500's a few weeks ago and got the following per engine.
3200 RPM = 18 GPH 3800 RPM = 24 GPH Multiply that x 3 and you should be close. |
For me to buy a triple engined boat, it would have to be a real good deal That is one thirsty boat, not to mention three oil changes, three tune-ups and questionable resale value.
Dock Holiday, what speeds are you running at those rpm's? Would like to to a mpg equation...... I'd expect to see 1mpg at best with twin 500's just going by the numbers they post in the magazines. And with trips, I would think you would be under 1mpg....
So if you could post the speeds at your rpms, would appreciate it.. Have any numbers at higher rpms? |
As ya'll know, when gas was $1.50-2.00 per gal (which I thought was alot) I still didn't sweat it that much. But when you have to spend over $300 dollars to fill up your boat (at the gas station, not even considering premium fuel at a marina :eek: ), I figured I would ask to see if it was even worth entertaining the idea.
The only reason I would entertain the idea is that it could be a heck of a good deal! I'm guessing the cruising speed (3000 Rpm?) should be around 50 MPH? |
I've had similar bad thoughts about the Mack Daddy Formula 419 - just the *bling* factor might be worth it!
But.... unless you can afford to wipe your bottom with $100 bills.... ;) |
I'd figure .75-.80 mpg.
| All times are GMT -5. The time now is 01:30 AM. |
