thermostat hole id?
hey guys im running a little too cool and am not running thermostats as i have crosovers. i wnt to bump my engine temps and am going to make 2 round plates to restrict water flow out of the thermostat hsg. what size hole should i start with. im running 130* wfo and wnat 150 to 160* wfo. any body ever do this on a boat? a friend of mine did this type of set up on a sbc in a chevelle and it worked well in his car. moroso sold a kit in alum, i want to make them out of ss. what is the od of a bbc thermostat? thx for any input. ratman
Re: thermastat hole id?
Originally Posted by ratman
..thermastat...
The kits come in 5/8, 3/4 and 1" ID holes. The 5/8" still gave me to much WP, 1" not enough. 3/4" resulted in perfect pressure and somewhat acceptable temp. No idea on the OD
us1 fountain what was your temp with 5/8 and 3/4? what engines are you running? thx a bunch ratman
glh never did a search, my bad on sp, thx
us1 fountain, who made your kits? are the discs alum or ss? thx again, ratman
Mine where AL. You can buy them in a 3 pack from Summit and Jegs for only a couple bucks. Didn't run the 5/8 long enough to get a temp reading do to higher than desired WP. With the 3/4", WP was 18psi at WOT, temps right at 120* during the summer months. This was on my blower motor. Never could get higher water temp.
Summit: Water outlet restrictors, Alum $7 pt #MOR-63440 SS $10. pt# CSI-900RP (Couldn't get a direct link to work) |
| All times are GMT -5. The time now is 09:14 AM. |
