-   -   What is the fastest single engine Offshore V Hull (https://www.offshoreonly.com/forums/general-boating-discussion/116644-what-fastest-single-engine-offshore-v-hull.html)
Titan 11-19-2005 12:45 PM
Re: What is the fastest single engine Offshore V Hull
Originally Posted by LIOPA
TITAN.....every post on this thread as well as most speed posts use whole numbers for MPH. If it's that critical for you I will try to find out to the 100th / second for you.
We have a 2004 35 with 525's.....93.7 GPS :drink:
Magic Medicine 11-19-2005 01:01 PM
Originally Posted by activator92
it says offshore boat not bath tub boat
Looks like if it's not an Activator it is a POS!!!! :blaster:
According to your logic, I guess my Nordic is a westcoast POS. :rolleyes:
I have been on Check300's boat and it is sweet to say the least. It is a very clean boat and you aren't likely to run into one like it.
mwdill 11-20-2005 08:45 AM
yea,
i have seen this trend also :rolleyes:
Velocity Tom 11-20-2005 12:35 PM
Didnt Steve from t.m.p. have 28 phantom that ran close to 120mph?
375stinger 11-20-2005 01:38 PM
my 18 check runs 75 :drink: ....but seriosly i think the best single to go high speeds would be 28 batboat with a turbine wit a big arneson... :evilb:
lvrepoman 03-10-2011 08:14 PM
The record, so I've found in my research, is 130.6 set by an orange Howard bullet 28 with somewhere around 1300 hp.
mptrimshop 03-10-2011 08:26 PM
i'm sure it has changed quit abit in 6 years:drink:
TUFFboat 03-10-2011 09:01 PM
We are going to speculate a little because we simply did not try this yet, but going by the numbers and calculating using the on-line 'speed calculator', the TUFF 28 that went 95.5 mph with a completely stock Merc 525 and a mere bravo prop, is culculated to go 115 mph with the Illmor/ indy 725.
Uncle Dave 03-10-2011 09:55 PM
As far as I know its the Howard.
Uncle Dave
tabajay 03-10-2011 11:38 PM
Originally Posted by TUFFboat (Post 3347621)
We are going to speculate a little here but going by the numbers, the TUFF 28 that went 95.5 mph with a completely stock Merc 525 and a mere bravo prop, is culculated to go 115 mph with the Illmor/ indy 725.
Love that boat.
