Re: Hull protection when traveling?
what brackets do you use US? Got pix of how you rigged?
Originally Posted by Downtown42
That is different. Took me 2min to see what you were explaining. thanks.......Do you use the nets for smelt fishing? :evilb:
Thanks! Looks good to me...add some silver naked women and you'll be stylin :cool:
Can't be worse then this...
1 Attachment(s)
Originally Posted by US1 Fountain
Do now. Basically it is just a peice of 1x1 angle iron that extends the full lenght, with 2 short peices welded to it that extend downward along and past the 2" reciever with a bolt under the bottom to claamp it tight. I installed the 2 diagonals not knowing if I needed them. Like I said, not pretty but it works great.
That's how I made mine as well, a piece of angle iron, mud flaps from a truck supply place and a u-bolt that goes around the bottom of my receiver with 2 holes in the angle iron. All the weight sits on your receiver so the u-bolt basically just holds the angle iron from moving. Cost me about 40 or so dollars with the mud flaps being the most expensive part. Just cut them down to the size you need. Not the greatest picture but you can see them on the truck, I bought blue mud flaps to match my blue trailer and put some crome brackets on them so they wouldn't sail. They sit about 2 inches from the ground and have no problem covering up those 40" tires.... |
Shrinkwrap the bottom...... :p :D :D :D
thank you for all suggestions :D |
These have adjustable arms to raise or lower the height of the flaps. 240 bucks.
http://www.genosgarage.com/CoastalDa...D=1607&CATID=1 |
| All times are GMT -5. The time now is 04:14 AM. |
