What's the main benefit of a center tab on a cat?
Besides improved planing and a better ride in rough water, what else does a center tab do on a cat?
Here's a hypothetical question? After trimming the bow up is there any chance of gaining speed by lifting the stern with the tab, thus lifting entire boat for less drag??
A to Z
Re: What's the main benefit of a center tab on a cat add speed?
Originally Posted by Sean H
the tunnel tab can gain you some serious speed, but can put you on your head to if your not careful... (this is why offshore race cats have tunnel tabs, not for planing reasons..)
How much more on a 28 Daytona 496 ho's? low 90's
A to Z
At about what speeds will the gains start to happen and how much more speed?
Re: What's the main benefit of a center tab on a cat?
Harper220,
The Kplane that Eliminator installs adds 1 - 2 mph in the 115 -120 mph range on a 28TD. It helps when planing with big props such as 36" B1s. Their other use is a step to get in boat.
Originally Posted by rbtnt
Harper220,
I'd like to find another 6-8 mph without going too crazy. I've considered Imco shorties or boxes, but can't seem to get much feedback on oso. I spoke with Mike at Eliminator and he suggested Imco 2" shorties with a 1" spacer to bring the x dim up 1". Not sure why he recommended doing it that way, but he said I'd be able to go up 2 prop pitches and gain 6-8 mph. Does this sound realistic?
A to Z
Which in turn does what on a cat? More lift?
look at the bottom of UIM cats or bigger cats, their compression flap will match the tunnel exactly..
