Dry Exhaust Vs. Wet
What are the pro's & con's of going with dry exhaust. I am building a new boat and trying to decide.
I think I may want dry so there is no soot on transom and no exhaust mist blowing back on the boat. Anyone's experience would be appreciated. |
Re: Dry Exhaust Vs. Wet
"Noise laws"...that should help you make a choice...
Noise is not a concern as I will likely add mufflers.
If the engine is creating soot I would think it would get on the transom weather the exhaust was dry or wet.
The dry exhaust still has water spray it just doesn't get discharged untill the end of the tails. |
2 Attachment(s)
http://www.h20htr.com/videos/neilsboat.wmv |
That sounds NICE!
That sounds great -
You have dumps - I did the same think with mine but I run the water so that it sprays onto the sides of my drives. Most of the dry exhaust I have seen have the water spraying off the end of the tails. |
They say the "dry" is louder, but the advantage to a dry exhaust is you have no worries of which cam to use. No reversion issues.
that's the biggest advantage. |
Advantages......no reversion issues. Loud as hell.
Disadvantage.....Loud as hell.:) Hard to bring into compliance even with mufflers. Few mufflers currently available that are compatable with dry pipes. {GGB Extremes} All pretty well pointed out in everyones previous posts. ;) |
