Like Tree0Likes
Advantage v Disadvantage of not running a thermostat
Old 01-06-2006, 07:20 AM
CMG
CMG's Avatar
My Boats: 1998 Aquasport 205 Oosprey
Default Re: Advantage v Disadvantage of not running a thermostat
Quote:
Originally Posted by Audiofn
Don't mind CMG he is that guy in the Burgerking video "DING FRIES ARE DONE"
Chris G.
CMG is offline
Old 01-06-2006, 09:09 AM
My Boats: None
Well, first of all with an EFI/MPI engine, don't even THINK of running without a thermostat. The engine will be in a rich mode way too long and the combustion chambers will load-up with carbon deposits. They could start glowing and cause detonation.
I have seen removing the 'stats and the overheat stop, but you fixed the result, but not the cause...unless the thermostat itself was no good.
Check the risers for possibly being plugged and keeping the water in the engine too long, or you just may have a failing raw water pump impeller.
Don't forget the "Bravo Syndrome" as a possibility too.
Edward R. Cozzi is offline
Old 01-06-2006, 09:14 AM
gripit's Avatar
My Boats: 1988 Cigarette Bullet
These are 420HP's with carbs and TRS setup.
gripit is offline
Old 01-06-2006, 09:20 AM
CMG
CMG's Avatar
Gripit just an fyi, I replaced the thermostats twice in mine (89 454mags), new impellors and my risers were ok. I never resolved the problem other than removal.
Chris G.
CMG is offline
Old 01-06-2006, 11:29 AM
My Boats: None
Quote:
I also have seen clogged thermostat housings give similar symptoms.
Old 01-06-2006, 12:10 PM
gripit's Avatar
So, you guys are saying that saltwater corrosion, constricting the water flow probably led to problems with overheating, therefore, the previous owner took the thermostats out. And I should probably leave them out?
gripit is offline
Old 01-06-2006, 12:16 PM
Clay Washington's Avatar
My Boats: 1990 Cigarette Bullet
Whipple recommends that you remove the thermostat when you install their supercharger. I ran several seasons with a Whipple and no thermostat with ZERO problems.
Clay Washington is offline
Old 01-06-2006, 12:18 PM
My Boats: None
Talking Re: Advantage v Disadvantage of not running a thermostat
Quote:
If it was me, I would fix it so that the engines would run at the correct temperature WITH the thermostats installed, but what do I know, I've been married 5 times!
Old 01-06-2006, 01:21 PM
CMG
CMG's Avatar
good point
I tried honing the housing out to clear up the passages, it becomes like cement, I should have replaced them but figured it ran well withouth the therms so..
5 TIMES? I think after smashing my nuts in a vice once.....
Chris G.
CMG is offline
Old 01-07-2006, 10:08 AM
My Boats: None
...and some people think I don't take marriage or women seriously enough!
djmadmatt
43
04-08-2017 02:55 AM
fountain27ho496
02-24-2007 12:43 PM
ratman
9
01-07-2006 12:48 AM
Jan
06-23-2003 11:03 PM
Jan
Advantage
5
02-22-2002 03:51 PM
