-   -   Circulating pump delete (https://www.offshoreonly.com/forums/general-boating-discussion/121134-circulating-pump-delete.html)
JasonSmith 01-23-2006 05:26 PM
Anyone remove the factory circulating pump & replace with a crossover on a 454/502 MPI merc motor?
copiercat 01-23-2006 05:51 PM
Re: Circulating pump delete
depends on the brackets and belts/pullies your running
i had to run one unless i wanted to pony up some serious bucks to change everything
so what i did was to remove the impellor from it and seal it back up, they take about 30 hp to run,
i just run the merc sea pump
JasonSmith 01-23-2006 08:18 PM
So you just pull the impeller right?
CAP071 01-23-2006 08:19 PM
is it worth all the hassle on a stock motor set up for maybe 25-30hp?
Codered 01-24-2006 06:22 AM
This is a interesting topic to say the least. It has been discussed many times on the technical Forum. The first thing I found out is that 25to30 HP is a Extremely far stretch as far as HP gains. The second major problem people talk about is water pressure amd plumbing in water dumps and relief valves. I personally have put one on a 365 Magnum , carbed and noticed no gains other than cosmetic " Cleaned up the front of the engine" . When i started hearing about water pressure issues and blowing out intake gaskets and the like it scared me. I switched back to a circ. pump. I have seen many engines on this site with crossovers and it didn't appear tha they had water dumps or relief valves and they must run just fine . Ihave ask the question before about crossovers being just a direct bolt on as advertised and could never get a straight answer. If you need relief valves and water dumps with crossovers why dont the companies advertise them like that . Just my 2 cents
birdog 01-24-2006 06:54 AM
A huge can of worms for 5-7 hp.not 25-30
klaw 01-24-2006 08:20 AM
yes when people say 30 hp just look at the fractional hp belt that drives it and you realize it prob less then a few hp
I did mine and it looks good but no real performance in crease
Scott 01-24-2006 10:04 AM
For once I agree with Birdog :drink:
Not to mention you typed "just remove the impeller right?" Uhhm NO please do a search in the Tech section. You may want to enjoy your Turn-key boat and look elsewhere down the line for speed gains.
You may want to have your props worked on for a nice change without spending too much and having engine damage or hotspots.
Call one of the board prop sales/repair sponsors and work with them on custom work. I use Throttle-Up and have heard great things about B-Blades.
JasonSmith 01-24-2006 10:28 AM
Props are done, drives are done. I just have a case of winter "what-ifIdidthisitus". I'm getting ready to rebuild the engines at the end of this 2006 season. So I need to gather ideas & parts early so my wife doesn't have a fit this next winter.
birdog 01-24-2006 10:30 AM
In that case......................I'm changing my mind..... :evilb: :drink:
bryanspeedracer 01-24-2006 02:50 PM
I did it. It cleaned up the front of the engine and I fortunately have no water pressure issues. Engine temps are also very good w/ the 142 deg. stat.
My motivation was that the thermostat housing was ratty and deleting the pump got rid of one more thing to go wrong.
Speaking of which, I have two cir. pumps that are low hour I will give away just pay shipping...
Bryan
Boatally Insane 01-24-2006 05:23 PM
Bryan
I'd be interested in one or both...mine started leaking this past fall....
Thanks,
Doug
(262) 783-7262 Home
(262) 252-3377 Work
or
[email protected]
Codered 01-25-2006 03:08 PM
What motors Bryanspeedracer ? How can some people have water pressure issues and some dont .
Codered 01-25-2006 03:14 PM
dyno 01-25-2006 03:29 PM
1 Attachment(s)
I went with cam driven pumps, makes changing the impeller a snap and cleans evrything up...but it aint cheap mine, are not efi motors
Codered 01-25-2006 03:37 PM
Neat set up Water pressure peoblems ? water dumps? relief valves ?
birdog 01-25-2006 04:27 PM
I have the same...I think it's a slick set-up
bryanspeedracer 01-26-2006 12:41 PM
Twin 468's. I have no idea why some people have problems and others don't.
Each motor has a large engine oil cooler and a smaller trans oil cooler, starboard side has p/s cooler. Both sides have sea strainers.
Maybe that info helps? I don't have enough experience with these set ups to guess accurately.
Bryan
