-   -   Need Engines...... ...... ..need Engines (https://www.offshoreonly.com/forums/general-boating-discussion/122202-need-engines-need-engines.html)
LostinBoston 02-10-2006 02:25 PM
Re: Need Engines...... ...... ..need Engines
Originally Posted by wiggler4490
I think you will find that a 100-105mph nortech will be a ton less than a 125-130mph boat, over 850hp open wide. If you use it on loto, the 525's will push you as fast as you want to go. On the weekends 85-90 is all you want bvecause it is so crowded and rough, you just wont run 125mph but maybe twice a year there.
if set up right, 90 feels slow on these boats, even in a chop.
SkiDoc 02-10-2006 04:50 PM
Jeff, Looks good, who you gonna get to put the power in it?
WeaponX 02-10-2006 05:34 PM
That's definitely not as fast as I run at LOTO .Big water is where it's at. :evilb:
WeaponX 02-10-2006 05:37 PM
Originally Posted by customryder
trading the zr (pending insurance) following your need for speed :drink:
Bring it to LOTO if I still have mine we'll run around some. :D
customryder 02-10-2006 06:41 PM
Re: Need Engines......GELLNER project 2 Engines
Originally Posted by Bad Girl
I have a pair of 95% complete freshened 572sc 8.2:1 comp. engines that Dean Gellner has done all the work.Motors are still disassembled. All bearings and pistons have been fitted. block is GM tall deck, has been clearanced for stroker or large aluminum rods, as well as complete block machining. Dean has reviewed the project since I have had it sitting for the summer and has given me a ballpark estimate to assemble and dyno tune carbs, ignition and such.
Rough details
GM 572 10.2 tall deck, 4.5" bore, Internal balanced Crower 4.5" stroke crank, Crower 6.535" rods, Venolia flat top pistons and pins, ARP main and head studs, Crane roller cam,Isky springs, Crane Gold rockers, Ferrea valves, Dart alum 360cc heads w/ cast alum 2pc valve covers. Moroso oil pump,Manley roller chain cam drive w/ polished alum cover, Merc alum kickout style pan, Merc 420 Mega blower with 16 rib conversion including tensioner, Superchiller innercoolers, Holley twin 750 carbs, MSD distributor, Fluidampner balancer, SS crossovers, Hays lightened flywheel, polished alternators, and many misc internal components and external lines and fittings. Most all external bolts are polished stainless and many are ARP.
I had the motor completely assembled to make sure of fit and do the plumbing and then I disassembled to change the comp ratio by going to the current shorter rods. The rotating assy is already balanced and ready to go. A brief description of work to be completed is oil pan oil control mech, oil pump pickup, and then the heads I would reccomend valve fitment( guide fit, valve seat and valve fitment machining) Heads were skimmed flat, cut for preffered seals and misc. I don't have a detail sheet handy but most of the parts in these engines are new.
You can have Dean complete or you or your favorite engine shop. I would recommend keeping it all in one persons hands being Gellner.
please email me if interested in the package and you can also talk to Dean Gellner direct about details and specs of thier work as well as doin the completion. The work performed was under name Ken Helbling.
call me 270 442 1777 Jeff
JIMKID Motorsports 02-10-2006 07:17 PM
I Just Got Done Pulling The Motors Out Of That Beauty. And Those Arnosons Hadle Like A Dream .iv Run That Boat At 120 And Felt Like It Was On Rails. Gets On Plane Easy I Just Hope Jeff Knows What Kinda Deal He Got You Will Love That Boat Just My 2 Cents Jimkid
customryder 02-10-2006 07:22 PM
Thanks!! i cant wait to get it going.
dreamer 02-10-2006 08:03 PM
u forgot
with gellner power
dean51267 02-10-2006 08:11 PM
briggs man, briggs.............
customryder 02-10-2006 08:45 PM
you ment run from... i cant keep up.....but can i have one of those like in your avatar now? :D :p :chick:
