Like Tree1Likes
Look what I found out in a Barn !!!
Old 03-02-2006, 01:29 PM
  #81
Default Re: Look what I found out in a Barn !!!
Yes...boost is the key here....but you would need to run 116 octane..........93 octane would end in detonation and then kaboom..!!!
Being new to this, it seems this guy Sharkey is some sort of living lengend........
HuskerPerformance is offline
Old 03-02-2006, 05:45 PM
  #82
Hauling Trash's Avatar
My Boats: 22 Hustler
Because He KNOWS ALL................................
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
Hauling Trash is offline
Old 03-02-2006, 10:11 PM
  #83
OSO Content Provider
Commercial Member
SHARKEY-IMAGES's Avatar
Talking Re: Look what I found out in a Barn !!!
Quote:
Not me...
I'm just another retired Offshore Racer/Boat Builder that can't break the addiction of this sport...
www.TimSharkey.com/
Digital Photography & Video one BYTE at a time !
SHARKEY-IMAGES is offline
Old 03-02-2006, 10:13 PM
  #84
Commercial Member
Thumbs up Re: Look what I found out in a Barn !!!
I just found out that the Ignore Option really works!!!
"This message is hidden because Hauling Trash is on your ignore list."
www.TimSharkey.com/
Old 03-02-2006, 10:30 PM
  #85
Gearcase
gearcase's Avatar
My Boats: 95,28 skater,cig,stv euro
out law disk that might be the how sweet it is motors I think they had a set of those in 46 skater. carl myers was into race cars and race boats. they would beltch out some good flames when you get out of the throttle flying that skater.
gearcase is offline
Old 03-03-2006, 08:42 AM
  #86
Sonic30ss's Avatar
My Boats: 1987 Sonic 30 SS 1998 45' Wellcraft Excalibur
Quote:
Originally Posted by Reed Jensen
Roflmao..... Jimmy and Henry.... are there any bullet holes in the backs of the heads?.... lmao
Geezz It only took 2 days for someone to get it! I figured the NY guys would get it sooner
Sonic30ss is offline
Old 03-03-2006, 10:05 AM
  #87
Whiteknuckle's Avatar
My Boats: Sunsation Rocket
I'm thinking that an information source on these engines may be Mike D'anabelle at Sterling Performance. I believe that he worked with Bob Kaiser in the develpment of the small displacment turbo engines when he was at Mclaren. Did Kaiser then run in Europe with the turbo's?
Whiteknuckle is offline
Old 03-03-2006, 10:23 AM
  #88
Rocco's Avatar
My Boats: 2000 25' Concept w/ 250 Mercury
Bill Gifford is to busy building Subs
Well, Bills been talking about it for years and now he's finally doing it....building a submarine. This page will be an online, ongoing journal of the progress we make over the next few months, years, or decades until the sub is finished. So it begins...
Submarine Project
Designer: Bill Gifford, Gifford Marine Inc.
Builder: Bill Gifford, Gifford Marine Inc.
Length: 33 feet
Power: diesel electric
Submarine
Journal
5/16/01 Two weeks ago I started to build my sub. I believe I can finish the project in a year or two. I don't believe my hard costs will exceed sixty thousand dollars US. And I do intend to keep a log of my time.
Main Pressure Hull After 1st Cut
Showing Keel and Rolling Chocks
I have chosen to use two new propane tanks to form the pressure hull. Each tank is made of A-516 grade 70-pressure vessel steel, .270 inch's thick. Both tanks were pressure tested to 325 pounds. They have a working pressure of 250 pounds and are ASME rated with a spec. Plate on each tank. I am installing three by one half-inch reinforcement rings every two-foot on center. Plus additional deck and bulkhead framing. The one-tank measures 17.6 ft. long and the other is 9 ft. I have cut a hole in the top of the larger tank, around that I intend to install the conning tower, which is made up of parts of the smaller tank and additional plate. I have cut the ends from the smaller tank and have connected them on each end of the larger tank for hard ballast. I have purchased a eighteen-foot by two foot by quarter inch pipe for the soft ballast tanks. The pipe was split log ways and will be attached to each side, to form the side tanks. The sub will have a displacement of approx. 18,000 lbs.
It will be powered by two 20 hp. Advanced electric motors and a 21Kw diesel generator. I hope to have an 8 to 10 knot cruising speed, surfaced and certainly more than I need submerged.
The sub hull is going to be similar in design to the WWII Class VII Submarine. The conning tower will be more along the lines of an American sub, except for the addition of the view ports. The periscope will be fabricated from a hydraulic cylinder with a small camera mounted in the top.
The diesel generator will take its air supply through a double valve pipe and the exhaust will exit the same way. In this fashion I will be able to build air pressure between the valves before submerging to prevent water from entering the engine. The generator will be keel cooled.
The sub will seat two people one behind the other. It will be controlled by an internal hydraulic unit operating external rams. I also intend to equip the sub with small underwater cameras in different locations so that both crew members can get a better view of there surrounding.
The overall length is 33ft. and the beam is 6ft. the draft should be approx. 2.5ft. The subs soft ballast will be approx. 18 percent. The bow and the stern will be free flooding and contain shafts, rudders, trim planes cameras etc:
Bill Gifford
Rocco is offline
Old 03-03-2006, 11:08 AM
  #89
McGary911's Avatar
My Boats: Donzi Criterion
If you'd like to follow Bill's sub build, go here:
http://www.psubs.org/psub_pic/BillGifford5.html
Now........back to Sharkey's mystery motors......
McGary911 is offline
Old 03-03-2006, 02:18 PM
  #90
Cat man do's Avatar
My Boats: ELIMINATOR
Husker Performance, I Assume Your From Nebraska. I Know 1 Person In This Whole State That Would Have That Kind Of Knowledge. Is Your Name Kevin?
Cat man do is offline
DaveSunsation
01-05-2005 09:34 PM
wwwTOPDJcom
06-03-2004 01:19 PM
eliminator219
07-17-2003 07:47 AM
BRIAN73
03-04-2003 08:31 PM
Mr Gadgets
03-28-2002 06:44 PM
