Best place to buy marine AC system??
Where's the best pricing?
I was looking at this unit.
http://www.marineair.com/pdfs/L-2124.pdf
Found it here for 1399.99
http://www.boatersworld.com/webapp/w...atalogId=10051
Re: Best place to buy marine AC system??
I'm thinking about getting one of these......but I can't seem to find anyone who has tried it. Would be nice to find someone!!!
http://www.bayairac.com/
craig, i took look at that unit myself. i wonder how big a cooler of ice you would need to last a weekend? i plan to overnight some this summer on some of the little islands around here and dont think a good sized cooler of ice and beers etc would last more than a good afternoon in 90+ degree heat. is this the unit that someone said o/limits was installing in a lot of thier boats?
craig, have you had a chance to run your rig with the new mills yet? whats your top end now? did jc intall em too? let me know how it runs with the new mills, they do look sweet. rm
Rob
I have the Bayair system in my 39 Nor Tech and it needs a large cooler. The manufacturer says 70 quart. I only have room for a 20 quart and it only lasts about 30 minutes. The unit is a great concept but it needs a chiller or something because it goes through the ice way too fast!
Rob
Rob
The BAD Guy
I talked to them about this unit and they said about 80-100lbs of ice per night I think a reg unit run on shore power or small generator would be the way to go. You know you think to yourself that the bayair unit is so light and runs on 12 volts it would be great but with that much ice it doesn't sound too great. Unless your getting the ice where your staying and not more then 2-3 nights,although still seems like a pain in the azz..ok my .02 cents......you want change
Rob
Rob
That pretty much rules that out! Just out of curiousity, how much did it cost?
One of those Honda eu200 portable generators and a suitcase AC unit looks better and better!!
if you have to buy and deal with 100lbs of ice every weekend you can pay for a genset and on board unit in 2 seasons, one if your in fl and boat a lot
I put a 7k marine air unit in my boat last summer. Installed it under the front v-berth. I also got the honda e2000i to power it. The generator is extremely quite, and it will run my fridge, the AC, and my battery charger for about 7-8 hours on a gallon of gas.
