Trim Tab Help
Old 03-13-2006 | 06:19 PM
Too Old's Avatar
Default Re: Trim Tab Help
Originally Posted by Python82
Should i try to get them mounted on the flat part or is it ok to mount them they are on Dave M's boat????
I think you'll find Dave's mounting to be the most widely accepted location.
There's more than one train of thought on mounting location, but my personal preferance is Daves.
Here's a set of 28" tabs on an Extreme 29.
Too Old is offline
Old 03-13-2006 | 06:32 PM
Stormrider's Avatar
JC Performance Engines
Damn fred, those tabs sure look nice on that exteme!
Stormrider is offline
Old 03-13-2006 | 07:04 PM
Dave M's Avatar
Veteran: Navy
I've seen other 24 Superboats were the tabs are mounted further out than mine. I have a pad on my hull so I think having them closer in makes them more responsive. If they were further out I think it would take more tab to get the same result.
Even in VERY rough water I usually don't have to run them much further than neutral. With big tabs on a relatively small boat you have to watch out for "bow steer" if you run them to far down.
Is that swim platform under water when your boat is at rest? Looks pretty low? Mine's only a couple inches above the water.
Dave M is offline
Old 03-13-2006 | 07:41 PM
rws's Avatar
rws
I would say that you could probably space the steering cylinder mount to the rear,but depending on how sturdy that it is maybe a new or beefed up mount could be in order.if you move it back toward the rear,you may have to move it toward the port side of the boat to compensate .I am right now Rigging the stern of My python and trim tab location is up in the air right now. Boat is looking good .
Rob
rws is offline
Old 03-13-2006 | 09:02 PM
SUPERSTITIOUS's Avatar
I had put a Latham single external steering ram on a 24' donzi. the k plane was in the way. Latham made a neat transom mount bracket that incorporated a arm and welded to it to clear the tab. My problem was the the rams offered were either to long or to short. THe custom bracket did the trick. If you move the mounting point I suggest reinforcing it from behind with wood and glass
SUPERSTITIOUS is offline
Old 03-14-2006 | 08:58 AM
Python82's Avatar
The swim platform is just above the water when at rest. So, 23' or 28'??? what length are the 280 k planes?
Python82 is offline
Old 03-14-2006 | 06:08 PM
Too Old's Avatar
22 OR 23.....
Too Old is offline
26sonic
04-30-2008 03:08 PM
wet_rat
Sea Ray
7
09-16-2007 04:38 AM
26sonic
Sonic
8
05-12-2006 09:23 PM
Monty
6
05-16-2005 01:24 PM
MnFastBoat
05-04-2005 08:34 AM
