Re: Stereo Guys: amp question
Originally Posted by noboat
IF this amp can run on a 2 ohm load DO NOT RUN ANYTHING IN SERIES.
Run them in parallel - run speaker wires from 2 speakers to the left side of the amp and 2 speaker wires to the right side of the amp. Done deal - simple! :D |
Originally Posted by Boomer35
the amp will draw the ohms off what my speakers are correct, so even running them in parrellel, they will still draw the 4ohms right?
As long as your amp is 2 ohm stable wire in parallel. |
Also, I THINK this amp is rated at 100 watts x 2 RMS. So, if you run it at 2 ohms you should be around 130-150 watts x 2 RMS which puts you at 65-75 watts RMS per speaker. :D
The 2-ohm power rating of 200 watts x 2 (14.4 volts)
agreed,....... are there any cons to parrellel apposed to series, battery issues, or drawing too much power, over heating the amp or blowing the amp or speaker?
I would never run anything over 4 ohms. Just wasting power. I've never needed fader control so I always used 2 channel amps with 4 speakers on purpose so I could do exactly what you are doing now. Never had an overheating problem or dead battery. The only reason I bought a 4 channel this last time is because I bought 2-ohm speakers. :D |
Anybody know how running at 2 ohms instead of 4 or 8 effects the headroom and the dynamic range of a system?
| All times are GMT -5. The time now is 05:10 PM. |
