-   -   What To Expect (https://www.offshoreonly.com/forums/general-boating-discussion/125054-what-expect.html)
BY U BOY 03-16-2006 02:52 PM
What To Expect
What Can I Expect To See? Adding 750 Holly And Msd This Weekend. 454/b1 330. Also I Will Test This With 23p Mirage. Then With A 25p Mirage Plus That I Will Cut Down To A 24p.
Sent My Money For Whipple Off Today I Think I May Have Addressed The Envelope Wrong It Went To The Irs.
Payton 03-16-2006 07:21 PM
Re: What To Expect
about 335hp, maybe 350 if you change the exhaust. Sorry.
cuda 03-16-2006 08:00 PM
Re: What To Expect
I'd be interested in the results. I'm changing to a TBIV ignition, and a Performer intake. I'll do the distributor change this weekend. Still trying to decide on exhaust. I have a clearance issue on the exhaust.
BY U BOY 03-17-2006 09:23 AM
Re: What To Expect
NO APOLOGY NEEDED I KNEW IT WOULD NOT BE MUCH. JUST WANTED TO GET AN IDEA ON SOME NUMBERS. I WILL BE ADDING NEW HEADS AND EXSAUST BY THE END OF THE MONTH ALONG WITH A LARGER CAM TRYING TO GET TO 425HP
CUDA ILL LET YOU KNOW IF ANY INCREASE IN POWER.
Payton 03-17-2006 09:53 AM
Re: What To Expect
That sounds better. :cool:
PatriYacht 03-17-2006 10:01 AM
Re: What To Expect
If you're changing from a points dist. to an MSD, you may see quite a difference. I picked up 200 rpm's when I did it a few boats ago.
