Like Tree0Likes
Does fogging oil foul spark plugs?
Old 04-16-2006, 07:11 PM
Titan's Avatar
My Boats: 33 Stratos, Sweet 16 Donzi
Default Re: Does fogging oil foul spark plugs?
I always use Marvel Mystery Oil...
Titan is offline
Old 04-17-2006, 07:10 AM
CAP071's Avatar
What's the Mystery in the oil?
CAP071 is offline
Old 04-17-2006, 08:04 AM
My Boats: 24 superboat 750 h.p.
ATF works well too!
flash32118 is offline
Old 04-17-2006, 08:59 AM
Pantera1's Avatar
My Boats: NorTech
I use mystery oil also ..Occassionaly get a fouled plug or two but for the most part no!
I fog my two stroke outboards as well and those are usually ok in the spring but I usually change em out anyway since its a 2 smoke.
But to change em all every spring just in case is a waste IMHO
Pantera1 is offline
Old 04-17-2006, 09:16 AM
Geronimo36
Panther's Avatar
My Boats: 36' Apache Warrior / 22' Apache Scout
I use ATF or "Fogging Oil" but not the stuff that's in the spray can.
Panther is offline
Old 04-17-2006, 11:41 AM
mr_velocity's Avatar
Quote:
Me too, never had a plug foul in the 10 years I have been using it. I will also fog if I know the boat will sit for a couple weeks in the summer.
mr_velocity is offline
Old 04-17-2006, 02:44 PM
Rob
Trade Score: (6)
Strip Poker 388's Avatar
My Boats: Hustler 388
Quote:
Originally Posted by flash32118
ATF works well too!
That what I use to use ,But been tearing down motors ever winter
Strip Poker 388 is offline
Old 04-17-2006, 04:32 PM
Hydrocruiser's Avatar
Arrow Re: Does fogging oil foul spark plugs?
Quote:
This stuff is basically a light oil and an upper-cylinder lubricant that has been around for years.
Mercury Marine Fogging Oil is my personal favorite as the chemistry is designed to displace moisture very well.
The whole idea of fogging is that it helps protect against rust and corrosion during seasonal storage periods. Helps protect metal surfaces (cylinder walls, pistons, rings, valve guides, and intake system components) against moisture and humidity. Displaces water to help prevent damage from moisture accumulation.
Usually 2 ounces is all you would ever use and fouling should be minimal. Often times too much is used and then fouling is a big concern..
I am not one to use ATF for fogging...and would say to stick with a MARINE SPECIFIC fogging oil.
Here is what is in ATF fluid...
ATF typically contains the following components:
Dispersants
Sludge & varnish control
Antioxidants
Prohibit oxidation
Antiwear
Planetary gear, bushing, thrust washer protection
Friction modifier
Modify clutch plate and band friction
Corrosion inhibitor
Prevent corrosion and rust
Seal swell agent
Prevent loss of fluid via seals
Viscosity Improver
Reduce rate of change of viscosity
Hydrocruiser is offline
Old 04-17-2006, 04:57 PM
Geronimo36
Panther's Avatar
CRC makes fogging oil that comes in 5 gallon pails. It smells like Caramel, that's the good stuff..
Personally, I don't like the Aerosol cans. If you're doing anti-freeze and fogging oil at the same time it's a b#TCH.
http://www.crcindustries.com/marine/...x?PN=06070&S=Y
or,
http://www.crcindustries.com/marine/...x?PN=06069&S=Y
Panther is offline
Old 04-17-2006, 05:15 PM
OldSchool's Avatar
My Boats: Cigarette CC and Boston Whaler currently
Dispersants
Antioxidants
Prohibit oxidation
Antiwear
Friction modifier
Corrosion inhibitor
Seal swell agent
Viscosity Improver
I know that this question has been asked many times before...but I've never seen an answer. Do you own a boat and, if so, what kind?
I can't talk about it right now, it's being handled by the Postal Inspector. Those guys don't mess around!
OldSchool is offline
Gordo
4
07-28-2008 05:07 PM
ThirdBird
5
05-21-2008 06:45 PM
masi242
4
07-29-2006 09:55 AM
Rick G
5
09-05-2003 08:11 PM
Pure Energy
05-08-2003 06:31 AM
