LOTO- Sound Violations Worse than ever
#51
Re: LOTO- Sound Violations Worse than ever
Originally Posted by KiloKat
Not sure what you consider running hard. Have been to 150+ but not wide open. For those of you with number 6 drives, the setup I ran on my 36 was much easier and less expensive to accomplish. Same components though - lots of water, mufflers & turndowns that are under water when not on plane. And, before anyone asks, never ran it wide open with these either but did run 180+ briefly during last years "fun run" heading to Big Dick's.
Thanks for the information. This is very helpful.
#52
Michael - In my first 36 Race/Pleasure, I had the in-line mufflers full time before the transom and then added HPI's after the transom. Wouldn't meet noise limits. Now, I only use external mufflers but the key here are the turndowns that exit slightly below the waterline when not on plane. On my 36 race boat, I used HPI mufflers with Gibson turndowns. On my 46, I had Gibson custom fabricate the entire system to my specs. One final note, we run an excessive amount of water through the Sterling engines for a variety of reasons. Therefore, we have an excessive amount of water leaving the exhaust which also helps reduce the decibels when running. Water is very important here - the more you have, the less noise. Good luck!
Dave
Dave
Michael
#53
we rented a condo in june at loto guess ill call and cancel
Drive 7 hours to get a ticket ..toss off the lake no thanks ill go to cumberland or ky lake they want my money
#54
I wouldn't get too worried. It is like this every year. Every boating season, they always crack down hard, but by the time the lake gets busy, the Water Patrol is focusing more on BUI and boater safety violations. If you are within reasonable tolerance and use your head, you shouldn't have a problem. If nothing else, just stop shut off your motors and chill out. If they come over, tell them you lost power and can't get it started. Ask them for a tow back to your dock and they will undoubtedly get another call they must respond to......
#55
#56
Jawbreaker said it perfectly, that is the plan, and Dave I remember very well when you blew by me when we were over 150mph, that 36 was just stupid fast period.
#57
I have 2 sets of through-transom mufflers for sale in the swap shop here on OSO
http://www.offshoreonly.com/classifi...p?product=2183
http://www.offshoreonly.com/classifi...p?product=2182
Yes, I have no shame
#58
As JBK put it--Just use some common sense and keep an eye out for the patrol. If you see em change course and keep your speed down. My boat is very loud and I have had no problem yet on LOTO. I have been stopped in Illinois twice and fined but they never tested me with a meter. They just said it was too loud!!!
I have added turn downs this winter and we'll see what happens.
Smitty
Smitty
#60
KiloKat
