That is why BAM never runs them.
H@ber no more either ??? burned thru 6 in 1 spring
huber trans
Can you clarify? you burned up 6 transmissions just because of the thermostat?
Originally Posted by Fast1blue
(Post 3309052)
NO MORE CHECK VALVES 4 US :drink: |
Originally Posted by RunninHotRacing163.1
(Post 3309067)
check valve = restriction
Huber
Originally Posted by dueclaws
(Post 1707825)
i've been running hubers for five years without problems.
But i've also noticed the rising popularity of the bam transmissions. Does bam require a thermostat to keep the temps at 180 for clutch plate life? What's your experience? Due Mike dambrose. |
Huber
Originally Posted by weaponx
(Post 3309364)
it's not from over power thats for sure.:lolhit:
(Post 1707825)
Huber
Originally Posted by cig3
(Post 3308994)
that is why bam never runs them.
(Post 1707825)
Huber
Originally Posted by runninhotracing163.1
(Post 3308999)
h@ber no more either ??? Burned thru 6 in 1 spring
(Post 1707825)
Huber
Originally Posted by fast1blue
(Post 3309052)
can you clarify? You burned up 6 transmissions just because of the thermostat?
(Post 1707825)
| All times are GMT -5. The time now is 09:54 AM. |
