-   -   Removing Powder Coating? (https://www.offshoreonly.com/forums/general-boating-discussion/128904-removing-powder-coating.html)
R Addiction 04-30-2006 10:31 PM
I have a aluminum peice that is powder coated red......Can the red powder coat be removed and How? Thanks :rolleyes:
US1 Fountain 04-30-2006 10:40 PM
Re: Removing Powder Coating?
I've used acetone before with excellant results. Soak a few min, the coating just peels off in sheets. Other times it softens the coating and requires more work. Also have just blasted it off. Different types of coating will result in different ease of removal.
R Addiction 04-30-2006 10:42 PM
Thanks.....I'm going to try the acetone first :cool:
customryder 05-01-2006 08:26 AM
aircraft paint stripper for the tuff stuff
R Addiction 05-01-2006 09:36 AM
The mechanic in the next bay had some aircraft stripper on his bench laid it on and WOW :eek: I may just have the door and frame cleared!! looks great!! :cool:
Thanks for the info guys!! :cool:
satisfactionII 05-01-2006 08:08 PM
Soak it in a tub filled with Greased Lightning( full strength), let it set for about 5 days, remove part sparkling clean. Wear gloves.
R Addiction 05-01-2006 10:27 PM
1 Attachment(s)
Aircraft paint stripper works well..............
