Like Tree0Likes
How Can I Get A McGard Prop Lock OFF ????
Old 05-04-2006, 08:37 AM
Charter Member #139 /Moderator/Platinum Member
klaw's Avatar
My Boats: 1989 Cigarette Bullet cig 20 resto mod
Default Re: How Can I Get A McGard Prop Lock OFF ????
take the key and weld some higher nubs into it and take a hammer and Gentley (lol) beat it on the brass nut will deform and then you can tun it off
klaw is offline
Old 05-11-2006, 01:31 AM
Rob
Trade Score: (6)
Strip Poker 388's Avatar
My Boats: Hustler 388
It wasn't that bad .About 15 min.I took a die grinder with a carbide bit and cut the collar in half .Then I tried getting a pair of channel locks on it and it would get a good grip to turn it.So I just cut 4 groves in the brass nut and beat a socket on it and it came right off. It would be that hard to steel a prop if you could cut the collar s off easy.Keep that in mind
Thanks guys for the suggestions!!
Rob
How Can I Get A McGard Prop Lock OFF ????-b-max-5-9-06-002-medium-.jpg   How Can I Get A McGard Prop Lock OFF ????-prop-lock.jpg   How Can I Get A McGard Prop Lock OFF ????-aaaaaaaaaaaaaaa-005-large-.jpg
Strip Poker 388 is offline
Old 05-11-2006, 01:33 AM
Reed Jensen's Avatar
Quote:
Originally Posted by Strip Poker 388
I am SOL .I was trying to take the prop off and the teeth on the lock itself broke off The key is fine.Is there a trick besides a torch,air chisel or cut off wheel to get them off ?
With out damaging the threads of the shaft
Thanks for any suggestions.
Rob
How to get a McGard prop lock off?...just show the lock some of your nasty internet porn, stroke it a few times, and it will get off by itself!............
Reed Jensen is offline
Old 05-11-2006, 01:41 AM
Rob
Trade Score: (6)
Quote:
I don't have anything nasty, its all entertaining, informative ,educational and FREE I like the sugestion of let the girl suck it off better
Old 05-11-2006, 03:45 AM
ratman's Avatar
My Boats: michelob light scarab, sold, sailor now
strip next time, brake clean the nut and key, then apply a thin film of grease to the surrounding area, then mix up some jb weld coat the inside of the key with it, put that on the lock and put a strip of masking tape to hold the key on, let it dry overnight and unscrew it.
ratman is offline
Old 05-11-2006, 09:30 AM
Rob
Trade Score: (6)
Quote:
That sounds like a good idear as long as it doesent stinck to the prop threads .
Rob
Old 05-11-2006, 09:52 AM
racer-x6's Avatar
My Boats: Mid Stream Marine
IF THIS HAPPENS AGAIN, JUST PARK IT ON THE TICKFAW NEXT TO A CYPRESS TREE AND COME BACK THE NEXT DAY.
racer-x6 is offline
Old 05-11-2006, 01:44 PM
Rob
Trade Score: (6)
That wouldn't be all they got is the prob.
At least we learned something about TickFaw/Louisiana you don't leave your shet unattended!!!!!! I have allways heard of it being bad there but this is the first hand knowledge now
Old 05-11-2006, 01:52 PM
racer-x6's Avatar
SAD ISN'T IT.
racer-x6 is offline
Old 05-11-2006, 03:22 PM
My Boats: 27' Magnum
Whats really sad is that whoever took the drives probably sold them for a few hundred bucks cause they had no idea what it was worth.
Rob Missed you Sat. We got to the prop stop about 2:30 or so and left there about 5 or 5:30 then got a rope stuck in the prop.
amarket1 is offline
KAAMA
3
12-07-2006 07:31 AM
Triple-Trouble
6
03-29-2006 02:31 PM
mark30h
11
03-22-2006 09:45 AM
Airpacker
2
05-09-2003 10:37 AM
