-   -   Mericruiser 350 Mag EFI / Bravo 1 Flushing Routine (https://www.offshoreonly.com/forums/general-boating-discussion/130089-mericruiser-350-mag-efi-bravo-1-flushing-routine.html)
kswest 05-13-2006 08:53 PM
What's the by-the-book method for flushing these motors/drives. I have one of the few performance boats at my dry rack storage and the crew wants to make sure they are doing it right.
Thanks,
Kyle
Hydrocruiser 05-13-2006 10:07 PM
Re: Mericruiser 350 Mag EFI / Bravo 1 Flushing Routine
Thanks,
Kyle
Pull lower drain plugs and let water out....use a coat hanger to be sure the holes are open and not rusted or plugged.. Pull thermostats and pour a couple 2-3 gallons of "blue" (not red) engine anti-freeze with anti-corrosion agents..-50*F... while briefly cranking or running engine.
Store with drain plugs out and t-stat out...come re-commissioning..put plugs in..t-stats in and crank her up with flush kit or in the water.
GOODT 05-13-2006 10:28 PM
by the book every time out would be to run fresh water( tap/ hose) through the system long enough for the stats to open then about 5 min I aways recomend salt away also but Im just happy if they flush
kswest 05-14-2006 06:51 AM
Thanks. Where to hook up the hose though?
Kyle
