Mufflers on Stellings dry pipes???
Does anyone know of a muffler that will work with Stellings dry pipes with the water stingers. I know that an option is to re-route the water and dump it through the transom and put clamp on style mufflers on.... Just looking for ideas at this point.
Re: Mufflers on Stellings dry pipes???
Hope I understand your question correctly, but as far as I know you can still use a clamp-on style muffler on a stock Stellings dry tail pipe where the water exits out thru a small pipe that protrudes out about 1" from the exhaust pipe (this is the way a Stellings tail pipe normaly comes). It would obviously aid in keeping the mufflers cool vs dumping out thru the transom.
Originally Posted by Ike
My stellings have the water dump inside the pipe and i have imco slip on mufflers, works fine.
Originally Posted by thedonz
Craig why the hell are you putting mufflers on ? your getting old
jr Mike
jr Mike
Another option that I have considered is to get some 4" PVC pipe, some 90 degree elbows and some rubber gaskets and make some "Donkey dicks". If I can find some quick release clamps, it would only take me a a few minutes to put them on or take them off (I'm getting the transom step plates put on the back of the lift) while the boat is warming up or getting flushed.
Here is a picture of my slip. As you can see, people's houses are directly behind the boat. Just waiting on the piledriver guy and then my carpenter will build my catwalks and I'll be ready to rock!
Wow Craig you do have feelings......That's awsome that you were able to get a slip now hurry yourself back to south fl. These young women ( 21 and older) down here keep asking Bill and me about you
jr Mike
jr Mike
Craig,
I have a set of 4 mufflers that came out of my Stellings they have 4 hours on them. My pipes are big though 6in inside diameter.
If you are interested let me know.
John
John
