Like Tree0Likes
What is up with my drive? It seems to not want to trim in?
Old 07-15-2006, 10:57 AM
DRIVEN1's Avatar
My Boats: 2005 Fountain 47 Lightning is gone.
Default Re: What is up with my drive? It seems to not want to trim in?
Quote:
Originally Posted by FeverMike
Mike if you need me to tow your boat in the water to your lift or elsewhere please call me. I'll be on my cell most of the day
813-335-2937
I will probably take you up on that on Sunday if you are around. Maybe if you are taking your boat out you can stop in the morning before you head out? The tides look good in the morning but will be to low around noon and later. I am off to work and will check in later. Mike
DRIVEN1 is offline
Old 07-15-2006, 12:21 PM
Who Me?
FeverMike's Avatar
My Boats: 2006 38TE Fountain
Mike, I will be over in the morning with my boat. Call me tonight...very late is cool, we are up till midnight so it's ok to call.
FeverMike is offline
Old 07-15-2006, 12:29 PM
Thumbs down Re: What is up with my drive? It seems to not want to trim in?
Damn Fountains!
belowdeck is offline
Old 07-15-2006, 12:45 PM
BY U BOY's Avatar
My Boats: 91 Scarab 21' Excel/1999 Proline 200 sport
Put In Gear Then Try To Trim. This May Get It Down So You Can Get To The Lift For Repairs
BY U BOY is offline
Old 07-15-2006, 02:57 PM
H2Xmark's Avatar
My Boats: 1997 Fountain 35 Lightning
sounds like you have a bad solenoid for the trim down section, the solenoids are the same part number for up and down, they are about 25 bucks at a merc dealer, you might try to jump around the solenoid, dont run your engines in gear for a long period of time, the u joints will be in a bad angle if in trailer mode
H2Xmark is offline
Old 07-16-2006, 06:54 PM
Forum Regulator
Trade Score: (1)
Sydwayz's Avatar
My Boats: 17' Speedliner Cat & O.P.B.
Very wierd. Sounds like you have some debris lodged up in there.
Do not take this likely. I had this same issue. I had a problem with a drive not wanting to trim in correctly. Turns out the outer bell housing pins and bushing had a flaw inside the gimble. This resulted in my wear pads grinding together and eventually landing on top of one another, and my outer bell housing shattered and ripped the drive right off.
Sydwayz is offline
Old 07-16-2006, 07:09 PM
Steve_H
jump up and down on them
Old 07-16-2006, 07:40 PM
Trade Score: (1)
My Boats: 3600 Nor-tech Super Cat
pull your switch panel and check connections on back
brian41 is offline
Old 07-17-2006, 12:05 PM
DRIVEN1's Avatar
Mike ,
Thanks for towing me over to my dock.
DRIVEN1 is offline
Old 07-17-2006, 12:07 PM
DRIVEN1's Avatar
Quote:
You are right. The solenoid went bad on two motors at the same time? I am able to trim them down when bypassing the solenoids. I should have new ones by Wednesday. Thanks Mike
DRIVEN1 is offline
dloftis
Baja
8
03-12-2009 09:08 AM
bcarpman
1
07-05-2006 11:23 AM
26sonic
Sonic
8
05-12-2006 10:23 PM
375stinger
3
11-27-2005 12:31 AM
Grog
2
09-30-2003 08:36 AM
