Getting a little woozy and green
I've been thinking of moving up to a Donzi 33ZX from my 22ZX. Since the cuddy in the 33ZX is much more usable, I'm just wondering how I might be able to 'handle' it.
I get seasick pretty easy if I don't watch the horizon and I'm thinking that the new cuddy will be almost unusable because I'd get sick right away with any wave motion. Maybe something like the 28ZXO open bow might be more in order. I'm sure that there must be others on here that get sick. What do you do? |
Re: Getting a little woozy and green
Where about do you boat ?
i have sold acouple 33 donzi.. fun fun boat.. 496 you can get over 70mph.. and twins.. easy to haul with a 1500.. more room.. just a nice size boat..
With a 33, I would probably mostly be on Lake Michigan. Both on the Michigan side and on the Illinois side. I'm currently on the Chain of Lake in IL, and I may stay there with a smaller boat like the 28.
have you tried scopalamine patches?
SY, There is alot of good info in this long article. It's from the DAN Network, they are a safety organization that we divers are members of and recieve help from when there has been an accident.
Diving Medicine Articles Motion Sickness Some salty & sage advice on an age-old problem By G. Yancey Mebane, M.D. My experience with seasickness is that at first you are afraid you will die, then after a few hours you are afraid you will not. Seasickness, or motion sickness, ruins diving trips, vacations and travel for many. Everyone is susceptible, and motion sickness can be produced in anyone if the circumstances are right. A lot is known about motion sickness, but total understanding of the cause is not clear. There are individuals who are resistant to motion sickness, but sufficient angular acceleration will induce motion sickness in anyone. Even astronauts are annoyed by this problem. Approximately 70 percent of all crew members experience motion sickness of some degree during the first 72 hours of orbital flight on the space shuttle. Cause If you have experienced motion sickness, you probably think of it as primarily nausea. One theory says that this symptom is the result of your brain's inability to resolve the conflicting signals that it is receiving from the ears, eyes and body. The vestibular balance apparatus of the ears detects motion and is stimulated by the repeated angular acceleration of the dive boat. If you are in a compartment or have lost visual contact with the horizon, your eyes signal the brain that there is no motion. The sensors of body position are sending still another signal, and your brain is unable to resolve the conflict. Anxiety, confusion and dismay result, leading to the first symptoms of yawning, pallor (paleness) and headache. They are followed by nausea and vomiting, and frequently a "fear" response. That is the time you are afraid you will not die. There is more to the cause than mismatching of sensory inputs. Other hypotheses under intense study include the role of Coriolis forces (forces due to the earth's rotation), other nonphysiological stimuli, the cerebrospinal fluid and the cerebellum. A ship moves in a complex fashion depending on the size and construction of the vessel and the condition of the sea it is sailing. Among the hundreds of research studies on the cause of motion sickness, an interesting study from 1988 reports on sophisticated measurements of vessel motion and consequent seasickness among passengers on six ships, two hovercraft and a hydrofoil. This study showed that the occurrence of motion sickness was closely related to the magnitude of the vertical acceleration experienced. There was low correlation between roll and pitch acceleration magnitude and vomiting. This information won't cure seasickness, but it does tell us to find the part of the vessel with the least vertical acceleration and stay there. Usually that will be in the center of the vessel, and we want to stay as low as possible while maintaining eye contact slightly above the horizon. If visual contact is not possible, keep your eyes closed. It is prudent to stay away from individuals who are actively ill, though psychological support and reassurance from companions are helpful for the individual and the group. Have you ever advised a seasick diver: "Get in the water - you'll feel better"? That may not be good advice. Motion sickness underwater occurs for the same reason as above water. When underwater, spatial disorientation occurs because of the interference with the normal clues. Poor visibility and the visual field restrictions imposed by the mask distort or eliminate visual clues. Neutral buoyancy distorts the clues provided by gravity. Motion from surge which may be encountered during entry causes potent acceleration forces. The brain is unable to reconcile the abnormal sensory input, and motion sickness develops. Anxiety of some degree is inevitable no matter how laid-back the individual, and a panic reaction can easily occur. Vomiting underwater is not easy. Do you vomit through your regulator or take your regulator out of your mouth? There are valid arguments for both techniques, and I have seen both done successfully. There is no doubt that safety is seriously impaired under either condition. As an experienced diver, you will be able to recognize clues available during a dive which provide spatial orientation. It is important to enter and exit along a line if visibility is poor and the bottom cannot be seen. Gravitation pull on weight belts provides the "down" sensation, while buoyancy effects will cause the chest to rise. The feet will tend to sink when not swimming. Bubbles, of course, rise. An inexperienced diver may not respond to these clues, especially in a panic situation. And what about the reverse: sickness on land? It does happen. After you have finished that 10-day "trip of a lifetime" aboard a liveaboard and have stepped onto solid ground, you may suddenly feel funny and maybe even sick. What happened? "Land sickness," or mal de débarquement, occurs when you return to dry land after becoming adapted to an environment in constant motion. Your brain has become accustomed to the new input from increased motion. Suddenly, the motion stops. The abrupt change will promptly produce the same symptoms as originally felt upon going to sea. Motion is most of the story, but not all. Emotional factors (fear, anxiety, fatigue) act in concert with motion to precipitate an attack. Alcoholic or dietary excesses before or during the trip increase the likelihood of motion sickness. Jet lag, which results from rapid transition of time zones, places you out of synchrony with the local social and time cues, producing fatigue, loss of appetite, gastrointestinal duress and other symptoms. If you feel that way before the dive boat leaves the dock, guess what's going to happen on the way to the dive site! PREVENTION Now that you know that we don't fully understand the causes of motion sickness, you may not be surprised that we also don't really know how to prevent it. There are literally hundreds of gadgets, procedures, medicines, herbs, foods, etc., all touted as good for motion sickness - that in itself should tell you that none of these choices are completely effective. Perhaps you have already discovered a system that works for you. If so, congratulations. Be sure that your system is safe and stay with it. MEDICATIONS The use of medications to prevent motion sickness may be helpful, but none of the medications are free of side effects. As most of the side effects affect performance, there are serious questions concerning their use by divers - who must be alert at all times. You must be cautious in their use, and your best plan is to avoid them entirely. If you choose a medication, give it a trial many days before diving in order to determine the response and side effects for you. Antihistamines The most commonly used medications are antihistamines, available without a prescription, and similar in their side effect profile. The medications include Dramamine® (dimenhydrinate), Bonine® (meclizine), Benadryl® (diphenhydramine) and Marezine® (cyclizine). The common feature of this group is drowsiness, which could seriously impair a diver's ability to perform safely. There are other side effects - you should study all the information which comes with the medication before using it. Phenergan® (promethazine) is a prescription drug chemically related to the tranquilizers, and it also has antihistamine properties. Drowsiness is a prominent side effect, and it can be used as a sedative-hypnotic. The drug may impair your mental and physical abilities required to perform potentially hazardous tasks. Alcohol and similar drugs accentuate the sedative effects of promethazine. Intramuscular injection of this drug can provide great relief for severely motion-sick individuals. Of course, diving would be out of the question if intramuscular injection is needed. Other Medications Scopolamine-dextroamphetamine (a combination of 0.4 milligrams oral scopolamine and 5.0 milligrams oral dextroamphetamine) has been studied for use in the space program. These are very potent medications and are useful in situations for individuals performing complex tasks while being closely monitored. A recreational diver will have some difficulty in obtaining these drugs, as dextroamphetamine is a Schedule II controlled substance prescription drug and the combination has not been approved by the Food and Drug Administration (FDA) as indicated for motion sickness. A physician prescribing this combination for motion sickness will be outside the FDA indications. Trans-Derm SCOP® (scopolamine patch) is used for motion sickness and has been used by many divers who found it beneficial and reported few problems. Trans-Derm Scop does have some unwanted side effects which affect diving adversely. Dry mouth occurs in about half of the users studied (non-divers) and is probably more prevalent in divers due to the dry air in scuba cylinders. Blurred vision after about 24 hours' use is common and may persist after the patch is removed. Repeated applications will cause visual disturbance to increase. If your finger contacts the medication side of the patch and then your eye, the pupil will dilate. Wash your hands thoroughly after handling the patch. Trans-Derm SCOP® occasionally causes hallucinations, confusion, agitation or disorientation. These effects are more common in children and the elderly. Therefore, children under 10 should not use the patch. The dose is fixed and cannot be altered by cutting the patch, which also disrupts the rate-limiting membrane delivering the medication. The package insert contains the following precautions: "Since drowsiness, disorientation and confusion may occur with the use of scopolamine, be careful when engaging in activities that require mental alertness, such as driving a motor vehicle or operating dangerous machinery, especially when you first start using the drug system." Studies indicate that the patch is slightly more effective than Dramamine®. Dilantin® (phenytoin) has been shown to protect against motion sickness in several studies. However, the medication is an antiepileptic drug and has not been approved for use in the treatment of motion sickness. It is a fairly safe drug, but not free of side effects and adverse reactions. There has been one study on divers in chamber tests at 460 kilopascals (approximately 150 feet/ 46 meters of seawater) which did not reveal any change in susceptibility to nitrogen narcosis. Royal Made Ping an Dan (PAD) is a royal clandestine prescription of the Qing Dynasty Imperial hospital for emperors, empresses, ministers, imperial maids and eunuchs. Experimental study has confirmed that it is effective on motion sickness. There is no information on composition or drug safety for this preparation. NONPHARMACOLOGICAL INTERVENTION There are many devices, herbs and procedures which are advocated for prevention and treatment of seasickness. The efficacy of both pharmacologic and nonpharmacological agents is difficult to determine in this condition, which has such a powerful emotional component. The placebo effect is very strong here. It is also complicated to determine if the agent used to prevent an event was effective or perhaps the event was not destined to occur. For instance, I keep a charmed shark tooth in my office to prevent shark attack. There hasn't been a shark in my ninth-floor office since I got that tooth - that's 100-percent effectiveness. There are enthusiastic advocates of ginger for prevention of seasickness, but its efficacy has not been substantiated in controlled laboratory trials. Seabands® (elasticized wristband devices) are sold as a means of treating seasickness. There is a stud incorporated into the device which applies pressure over the Neiguan point (located within tissue about 3 centimeters above the wrist joint). The Neiguan point is reported as being implicated in the control of nausea and vomiting, although the results of acupuncture applied to this point are contradictory. Seabands have been available for several years, although no controlled trials demonstrating their effectiveness have been published. FINALLY... So, how do you reduce your risk or susceptibility to motion sickness? First, you should be adequately rested, nourished and hydrated. If you are apprehensive, avoid placing anything at all in your stomach during the two hours more or less before you embark. You will be more comfortable with an empty stomach than with a full one. Adequate rest and hydration means that you have essentially recovered from jet lag, excessive food, or alcohol, and have satisfied your usual requirement for sleep. After boarding, prepare your gear for diving before the boat reaches open water so that you can avoid working on diving equipment while looking down. Find a place on the boat where the motion is least and stay low. Avoid the bow, flying bridge or upper decks where the motion is intensified. The motion at the stern is not unpleasant, but exhaust fumes may be present. Maintain eye contact with the horizon or slightly above. If you are using a medication or device to prevent sickness, have faith and it will probably work. Remember that all medications have side effects, and you should have tried the one you will be using long before exposing yourself to motion. The nonpharmacological agents are usually harmless, but you must be certain about your choices. Adaptation to motion does occur with most individuals, so that motion sickness frequently ceases after a few hours. Motivation and willpower are important, as are sounds, sights and smells; individual tolerance to motion is also a factor. Seasickness is an unpleasant acquaintance, testified to by armadas of past, present and future sufferers. (c) March/April 1995 Alert Diver. G. Yancey Mebane, M.D., was the DAN Associate Medical Director & Director of EMS Training at the time of this article. |
Its worse with a hangover :(
I use Meckizine 25m.... I dissolve it under my tongue get to the blood stream quicker :rolleyes: ..... I use it When I first get up in the am before going out in the boat when I know the water is going to be ruff, .I never puked but be close,its not a good feeling :( The longer boat doesen"t make much difference its the side to side rocking that gets ya |
| All times are GMT -5. The time now is 04:48 AM. |
