Hello everyone
:evilb: I finally decided to join. Always enjoyed the reading material on here but never really found material applying to me and my boat. I'm the proud owner of a 1987 24' Advantage offshore.
I have the king cobra stern drive, thrue hull exhaust and a OMC 460 (ford :mad: ) engine. I got my hands full of grease and oil by replacing the engine twice (I bough the boat with a blown engine cheap price 5500$). After the first one went I decided to try to improve the engine output a little. In stock form the engine is rated at 340HP which isn't enough by my standard. So I got a comp cams 262h marine, put in the magnum roller tips rocker with screw-in studs and played a bit with the carb. I took a look inside the distributor (prestolite :mad: ) and found that the mechanical advance spring were not even the same. One would have been fit to be used for suspension on a ten wheeler. So a lot of sorting out and tickering around but finally got my first day out yesterday where I won't have to put in corrective maintenance after sea trials. My goal in joinning here is to discuss some of the issues that I have a hard time to deal with and hopefully fix. Sure hope to get help and make friends around here. I in Halifax, Nova Scotia, Canada and the Atlantic is now my playground and I can see it becoming addictive. Have a good time out there everyone. Josh |
Re: Hello everyone
welcome.....
Re: Hello everyone
Congrats on boat and welcome :evilb: :D
Re: Hello everyone
I guess that means you brought the beer???? :D
Re: Hello everyone
:( I wish I could but I can't. The reason I came back last night was that the tiny cooler fitted onboard has been severely depleted (by my passengers of course). :drink: I'll be better prepared for the next time.
Josh |
Re: Hello everyone
wecome aboard, i suggest you invest in soap on a rope if you plan on hangin with that stecz guy :evilb:
Re: Hello everyone
Welcome Josh!
Re: Hello everyone
welcome to you new addiction :D ....and try not to forget about your wife...because it does happen
mike |
Re: Hello everyone
Wife??? :evilb: :evilb:
Do I really need one? I'm not as lucky as some of you guys do, like getting married, having kids then sometimes Godforbid, going through a nasty divorce and lose all the toys. Haven't met the one for me yet. But on the dockside I've seen a few that'd need some looking into but then the girlfriend might get jealous for no good reason. :( A very wise man told me that women are like engine oil. If you get the good expensive stuff like synthetic, you stick with it, otherwise change it often and regularly. :D lol |
Re: Hello everyone
rotflmao welcom josh . :drink:
| All times are GMT -5. The time now is 08:40 AM. |
