Will Silent choice for Bravo bolt up to TRS drive??
I have a guy that wants to buy my silent choice but he has twin TRS drives and i had the kit installed on Bravos. Are the two compatible or is there some kind of adapter. Thanks in advance
I had silent choice for Bravos set up on TRS's on my old boat.
The trick to making it work is to get stock TRS inner exhaust elboes that bolt to the inner gimbal plate with three bolts per side(Merc dealer). Then, you get rubber connecting boots that go from 4" down to 3" (Boat U.S.). I hope this helps, let me know if you need more info. Dave |
Can you use the bravo wishbone pipe or y-pipe that comes w/ the system or do u have to make something up w/tubing and the hose reducers you mentioned? Thanks
The stock inner TRS pipes take the place of the Bravo "Y" pipe
Originally posted by panteraracin: <STRONG>Can you use the bravo wishbone pipe or y-pipe that comes w/ the system or do u have to make something up w/tubing and the hose reducers you mentioned? Thanks</STRONG> I'm sure you can still get the TRS pipes from Merc if need be...or maybe someone here may have a set for sale :) |
| All times are GMT -5. The time now is 09:41 PM. |
