Any GM CRATE MOTOR sellers on the board?
Originally Posted by Thunder Struck
Thanks for the quick response everyone.
Jeff32, what was your cam selection, I assume roller and final choice of piston / compression? Did you just clean up the heads or do a valve job?
Trevor
Trevor
Trevor
Trevor
Just to throw this in the pot .... I have 2 502 MPI MAGS ..that have been freshened ( or in the process) ... we also added 500 EFI cams and Crane Gold Roller Rockers ....Also new forged pistons ... Also the ECM will be upgraded .... These are complete drop in motors ( no Exhaust) ....
Dean has first right to these motors if he still wants them .. I had hoped everything would be done by Sept 1 but it hasnt happened ... We did fire up the #1 motor last Friday and sounds pretty bad with the 500 cam ...maybe #2 complete by Oct ......8250.00 each .... If you need more info .... [email protected] ..............mike bell jax fla
Hey! Here is the link!
http://www.gmgoodwrench.com/
Once the homepage appears, go in the third column, and click on the gold letters GM PERFORMANCE PARTS. From there you can surf different subject.
I would be interested in knowing whos cam and part number. I have been informed that 420hp is about it for these engines so that is why I am keen on knowing what the internals are.
Information for you zz572 fans...
http://www.offshoreonly.com/forums/s....php?p=1371715
http://www.offshoreonly.com/forums/s...d.php?t=106361
